Activity › Forums › Adobe Premiere Pro › Brightness & Contrast
  • Brightness & Contrast
    Posted by Sethmace on November 2, 2006 at 3:45 pm
    https://www.sethmace.plus.com/misc/ScreenshotExample.jpg
    That is a screenshot of a video clip im using atm. As you can see because it was a very sunny day, there are issues with contrast & brightness. I’ve tried tweaking such settings in adobe premiere but I havent been happy with the results so far. Sure i can darken the image and in turn make some of the details stand out and reduce eye strain but the image looks dull and eventually lifeless.
    Could anybody provide post-production advice for premiere 1 to help correct such bright video?
    Thanks again!
    Sethmace replied 19 years, 10 months ago 3 Members · 3 Replies
  • Dave Friend
    November 2, 2006 at 5:22 pm
    It appears that the scene was so over-exposed that all detail in the bightest areas has been lost. There is probably no way to adjust the scene so it looks “normal” – the highlights have no data to work with.
    Bummer.
    Dave
  • Martin Rose
    November 3, 2006 at 12:40 am
    Try using levels ajustment
    Martin
  • Sethmace
    November 3, 2006 at 6:55 pm
    Thanks for the replies Dave & Martin. I was worried that the original would be so bad that I couldnt do anything but ill try the level adjustments. I did actually fiddle about with those settings but just found it greyed the video and lost the dynamic colour ranges. Will give it another go however:)
