Activity Forums Apple Final Cut Pro Legacy Brain malfunction: Does FCP 5.1 have DVCPRO 50 codec
  • Jeremy Garchow
    August 21, 2007 at 7:24 pm
    Yes, most definitely.
  • Nelson May
    August 22, 2007 at 1:38 am
    pardon my brain freeze, but I don’t see it on the easy set up pull down menu…..can I just use DV NTSC or do I need to load the codec from my install disk?
  • Jeremy Garchow
    August 22, 2007 at 3:07 am
    Click the little ‘show all’ box on the top let of the easy setup menu. Don’t use dv for dv50.
    Jeremy
