Activity Forums Adobe After Effects Expressions Bounce 3D layer at specific time
  • Bounce 3D layer at specific time
    Posted by Erik Lingerfelt on July 20, 2014 at 4:09 pm
    Hello Dan, everybody…
    It’s been a while since I’ve been here…
    So, I’ve searched all over and tried several expressions to do what I want, but it just doesn’t work.
    I got Dan’s Bounce with (his also) timeToStart I found around here, but the layer it’s attached to (position) won’t budge.
    I trie using the inPoint option also, and dragging the layer to show at 2 seconds – for which I removed all the “time” options, leaving only the raw Bounce expression… and still it doesn’t move. What I notice is that the expression starts over at 0 and by the time it get’s to 2 seconds, THEN I see a little movement.
    I hope I was clear on this.
    What can I do ?
    Thanks.
    Erik
    timeToStart = 2;
    t = time - timeToStart;
    if (t > 0){
    veloc = 10;
    amplitude = 700;
    decay = 5.0;
    y = amplitude*Math.cos(veloc*time)/Math.exp(decay*time);
    value + [0,y,0]
    }else
    value;
    Erik Lingerfelt replied 12 years, 1 month ago 2 Members · 4 Replies
  • Dan Ebberts
    July 20, 2014 at 4:33 pm
    Try changing this line:
    to this:
    y = amplitude*Math.cos(veloc*t)/Math.exp(decay*t);
    Dan
  • Erik Lingerfelt
    July 20, 2014 at 4:42 pm
    Hummmmm, yes! Thanks Dan!
    That worked for the bounce at set time.
    Now, as predicted, I need the layer to stay off screen until the bounce kicks in.
    I tried setting the last line to a value offscreen, but didn’t work…. 🙁
    Erik
  • Dan Ebberts
    July 20, 2014 at 5:40 pm
    Does the starting/maximum amplitude value put it off screen? If so, this should be all you need:
    timeToStart = 2;
    t = Math.max(time – timeToStart,0);
    veloc = 10;
    amplitude = 700;
    decay = 5.0;
    value + [0,y,0]
    Dan
  • Erik Lingerfelt
    July 20, 2014 at 5:43 pm
    Yes, indeed!
    What a cleanup in the code, huh ? 🙂 NICE!
    All I needed was the timetostart line…
    Thanks a lot, Dan. You ARE the one! 😀
    Erik
