Activity Forums Apple Final Cut Pro Legacy boris scrolling credits
  • boris scrolling credits
    Posted by Manuela Corbari on November 19, 2008 at 4:20 pm
    Hi guys,
    I’ve been trying to create smoothly scrolling credits with Boris but with no joy… I tried also adding deflicker and deinterlace effects but they still seem to be very jittery, any advice?
    Thanks a million
    Manuela
    Katrina maria Escay replied 17 years, 4 months ago 8 Members · 10 Replies
  • 10 Replies
  • Chris Babbitt
    November 19, 2008 at 5:07 pm
    Did you render?
    Try speeding up the crawl just a bit, or using a bolder font.
  • Alex Elkins
    November 20, 2008 at 12:37 pm
    Are you working in a progressive timeline? That has caused problems for me in the past.
  • Randy Lee
    November 20, 2008 at 4:30 pm
    Also, how are you monitoring? If you don’t have a broadcast monitor set up to check it on, you can’t know what the final output is going to look like. At the minimum, set the viewer to 100%, if it’s set to anything else it is likely to give you poor looking results. Also, rendering set to high quality, and this piece is fully rendered, correct? If you’ve got all of that and it still isn’t doing a very good job, feel free to give us full system and timeline specs so we know what you’ve got to work with and we’ll see what we can do for you.
  • Manuela Corbari
    November 20, 2008 at 5:04 pm
    Thanks everybody,
    will get a proper broadcast monitor in the next couple of days and check the scrolling credits on that, and then I’ll let u know
    M*
  • Manuela Corbari
    December 2, 2008 at 12:40 pm
    Hi
    I finally managed to check my Boris scrolling credits on a broadcast monitor, and still they look a bit jittery and out of focus.
    I’m working on FCP 6.0
    the sequence settings are
    HD (1440×1080)
    Field dominance Upper (Odd)
    Editing timebase 25
    Quicktime settings: compressor HDV 1080i50, quality 100%
    Video processing is set to render in 8-bit YUV, maximum white as WHITE, motion filter quality NORMAL
    The sequence is fully rendered, with same codec as sequence codec.
    it seems to be a bit better with the DE-INTERLACE (upper) filter and the 1:2;1 DEFLICKER in the Boris window
    Does anybody has any suggestion? Should I change some settings?
    Thanks a lot
    Manuela
  • Alex Elkins
    December 2, 2008 at 12:50 pm
    First thing – have you got your RT settings set at Full? If not, you might be simply viewing a half-res version of it, which would explain the out-of-focus look, which you may not have noticed just on your rushes.
    Personally I would remove the de-interlace filter as scrolling text generally looks smoother when it is interlaced (unless this is for the web). Keep ‘Deflicker’ selected though.
    Try changing your sequence codec to Apple ProRes 422, as each time you render to HDV it reduces quality slightly.
  • Tom Wolsky
    December 2, 2008 at 12:52 pm
    Assuming you have deflicker switched on in the Title Crawl controls, the it’s probably down to the content of the title, font, color, edging, shadow, speed, which will all impact the quality. If you’re working in an interlaced format you basically should not be using a rolling title.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Carolyn Lecorre
    December 8, 2008 at 9:01 am
    Here’s my suggestion and the logic behind it after reading comments on several forums:
    Everyone says FCP is really bad for dealing with text, especially scrolling text. You should use After Effects. I will agree, but I think I found a good way around having to buy After Effects just to do scrolling credits (because not everyone wants to buy or even bother learning After Effects).
    Having worked on a few projects along side graphic artists, I often incorporated their work from After Affects into my interlaced Timeline. Often, their work was outputed with the “animation” compression, giving a nice clean, non-interlaced product. I thought that perhaps if I created a timeline in FCP with the animation compression and used Boris 3d Crawl, I could get the same kind of output. Turns out I did. That timeline, I just exported as a quicktime movie and then re-imported it to my project and placed it in my NTSC timeline.
    Hopefully this will work for you
  • Richard Chenoweth
    December 21, 2008 at 4:49 pm
    I’ve been reading all these threads on scrolling credits.
    I made some scrolling text (five min.) in FCP6 and when it was in DVDPro Simulator it looked beautiful. When I burned the DVD it looked like hell. All fragged and wobbly and skittery. I had set it up with
    “none” and then used Compressor.
    Where is the Boris Plugin? It’s not in my “Extras” folder.
    I also tried to make this scroll in AE CS3 and AE couldn;t even render it. Kept running out of memory!
    I gave it 20 GB of scratch disk on my MacPro…
    Any more hints for getting good scrolling text?
  • Katrina maria Escay
    May 17, 2009 at 3:34 pm
    Thanks so much Carolyn! This works!
    Did some rushed motion graphics and this solved the interlace problem. Made sure to click on the “none” for the field dominance option on the timeline as well, and the de-interlace source video in the size option when exporting. Thanks for the help! Cheers!
