Activity Forums Adobe After Effects blue/green screening
  • blue/green screening
    Posted by Jhbrewer on December 10, 2005 at 9:39 pm
    I’ve recently become interested in special effects/video-in-general (picked it up from dad), and one thing that I’ve often thought to myself while working on the few projects I’ve completed is: I could do so much more if I could isolate that actor (and I don’t want to get into rotoscopy). I’ve known about blue/green screening and keying the actor out, but one obstacle that hinders me is that I don’t have a blue or green screen (or anything of a solid color that could be a backdrop). I figured that with all of the expertise available on these forums, someone would have a good wake to make or acquire one (preferably on the cheap side).
    Basilisk replied 20 years, 8 months ago 6 Members · 6 Replies
  • Michael Szalapski
    December 11, 2005 at 3:18 am
    Get some blue paint and “redecorate” the family room. Surely your dad wouldn’t mind; you’re following in his footsteps!
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great)
  • Justin Productions
    December 11, 2005 at 3:28 am
    You’re not necessary obligated to have a blue/green screen! Put yourself in front of a wall (with an unique color) and record yourself! Just one thing, don’t wear a color that’s the same as the wall behind you! Or better, you could use “Render->Paint Bucket” to paint your wall in real time.
    If you’ve got plenty of time to lose, why not masking?! *lol*
    Good luck!
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.0 Professional
  • Josh Miller
    December 11, 2005 at 5:32 am
    You can use many different colors when chroma keying, so don’t close your options just to blue and green! I used to hang up a piece of green fabric in my backyard on a clothes line, which I found to be suprisingly good. If you plan to do it indoors, which I recommend because of the variables of filming outdoors, it’s worth it picking up some cheap $20-dollar lights from your hardware store. You have to make sure you have even lighting when filming green screen.
    Josh M
  • Barend Onneweer
    December 11, 2005 at 1:11 pm
    Actually:
    You need a color that is at contrast to for instance skin color. So brown, orange, yellow or red would prove problematic.
    Second: the more advanced keyers are color difference keyers, and they need a good difference between color channels. So preferably a strong red, green or blue background color. We’ve already said that red is not a good idea for keying out human skin, so that leaves green or blue.
    Green spill is uglier on the human skin, but the blue channel suffers more from the DV compression so is usually more pixellated than the green channel…
    As far as lighting goes: you need a nice and even lit screen. Preferably a parallel light source. If it doesn’t rain, outside is usually the cheapest solution.
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Jhbrewer
    December 12, 2005 at 12:14 pm
    Thanks for the advice. I think I’ll try the colored sheet (green or blue) outside next time I start a project.
    Painting the family is tempting… but I don’t have any paint.
    You think your computer sucks?
    1.1 GHz Intel Celeron
    512 MB PC-133 SDRAM (upgraded from 128)
    17″ Gateway CRT + secondary 15″ ZDS (slow as christmas when I use it, though)
    2 x 20 GB, 1 x 160 GB HDDs (upgraded from 1 x 20 GB)
  • Basilisk
    December 12, 2005 at 11:20 pm
    I was going to try buying one of those big green plastic tarpaulins and maybe give it a coat of matte green emulsion paint. That would give a surface you could put on the floor and use as a backing. It is a good idea if you can stretch it to remove as many creases as possible. The Keylight plugin (AE pro only) is pretty easy to get a fairly good key with.
