Activity › Forums › Apple Final Cut Pro Legacy › Blu Ray Color Space
  • Blu Ray Color Space
    Posted by Stephan Hill on October 23, 2009 at 3:02 pm
    I am having a hard time understanding what the color relationship is in a HD video and a Blu-ray disc. Working with SD footage and now learning about HD I always assumed HD was useing a NTSC single and I would color correct using FCP NTSC scopes. I would then burn my HD footage on a blu-ray disc.
    the more I dig the more confused I get and it seems that HD footage is not NTSC dependent if I go from Blu-ray to HD monintor?
    Is a blu-ray disc using a NTSC single and there by its color space? If HD and Blu-ray has a better color depth or range then SD video then I would assume that I would not color correct it using a NTSC NTSC scopes and parameters.
    It seems applying a NTSC color space to a HD blu-ray single would be dumbing it down.
    Sorry for how dumb this question is!
    Rafael Amador replied 16 years, 11 months ago 3 Members · 3 Replies
  • Alan Okey
    October 23, 2009 at 3:12 pm
    SD and HD use different color spaces.
    SD = Rec. 601
    https://en.wikipedia.org/wiki/Rec._601
    HD = Rec. 709
    https://en.wikipedia.org/wiki/Rec._709
  • Stephan Hill
    October 23, 2009 at 3:24 pm
    thanks Alan,
    this helps out a lot. but I still do not understand why if HD has a better color range do we color correct with NTSC tools like the vector scope or Waveform monitor that are NTSC.
    I am an old Photoshop guy and I can’t help but think it is like color correcting my ProPhoto RGB 32 bit color photograph with Proof Colors on to Generic RGB.
  • Rafael Amador
    October 24, 2009 at 2:02 am
    [stephan hill] “this helps out a lot. but I still do not understand why if HD has a better color range do we color correct with NTSC tools like the vector scope or Waveform monitor that are NTSC. “
    Who say these are NTSC tools?
    Then the people in PAL land we can not Color Correct?
    What you need to color correct is a good monitor where you can change the color space depending of the stuff you are playing.
    rafael
    http://www.nagavideo.com
