Activity › Forums › Apple Final Cut Pro Legacy › black and white video in the canvas
Posted by Shane Trowbridge on July 21, 2010 at 12:48 pmI am having an inconsistent issue that I can’t resolve. For certain projects, clips turn black and white in the canvas when I highlight them. It appears fine until I highlight the clip to make an edit. This is causing issues for a particular project because it’s green screen footage that I need to key out and when I highlight it, it turns black and white. I’ve asked all my editor friends and no one seems to know what the issue is or how to fix it. Can someone help me?
Shane Trowbridge
Brian Miller replied 16 years, 1 month ago 3 Members · 13 Replies -
Jerry Hofmann
July 21, 2010 at 6:17 pmWhat is the format that you shot, and what are your sequence settings?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
Brian Miller
July 21, 2010 at 7:02 pmwell there are two things that should be checked – what kind of plugin are you using for your keys, and what is the codec of your sequence/clips?
GO BSU 🙂
Shane Trowbridge
July 21, 2010 at 7:18 pmwell, that is a great question. I’m newer to editing so I’m still trying to wrap my head around codecs and how they work. In this particular project I was given a DVD which I ripped using MPEG streamclip.(I later realized I should have just grabbed the video files off the DVD rather than ripping it) I’ve been known at times to mix codecs a bit on accident.
In this particular case I thought I had set the footage codec to DVCPro and I think the sequence was set to DV NTSC 48khz. I later went back and changed the footage to ProRes422 because Final Cut was wigging out a bit and running very slow. It ran faster but I was still getting the black and white effect in the canvas.
In some other cases the footage has been in H264 all giving me the same black and white effect. I should clarify that this happens for regular footage too and not just green screen footage.
I hope all that made sense. I could really use your help -
Shane Trowbridge
July 21, 2010 at 7:19 pmno plugins that I am aware of. just final cut 7 by itself.
I hope all that made sense. I could really use your help. By the way, I think I know you… -
Brian Miller
July 21, 2010 at 8:07 pmi definitely know u! hilarious dude!
ok this is what you need to do. make sure your sequence codec is the same as your clip codec. to do this, you can open a new sequence with whatever settings you want. then take your clip and drag it into the sequence. you should get a message that tells you the clip and sequence settings don’t match and it will ask if you want to change the sequence to match. Say yes. Then you will have a sequence that will play back your footage with no rendering. If you check the sequence settings of your new sequence, you can apply those setting to your problematic black and white sequence.
Oh and you can’t cut reliably with H264. Convert to pro res! -
Shane Trowbridge
July 21, 2010 at 8:11 pmsmoking! Thanks for the help.
are you still in LA? I was there until about 2 years ago.
Brian Miller
July 21, 2010 at 8:25 pmyup still here! did u go back to indy? oh and tim peresie says hello. we work at the same company now. fun times!
Shane Trowbridge
July 21, 2010 at 8:29 pmyep!
I moved back. In September it will be 2 years. I’ve been actually working steady as a freelancer. Was just doing some work in LA last week. Just got back to Indy yesterday. Where are you and Tim working? Tell him I said hello.
Shane Trowbridge
July 22, 2010 at 6:01 pmBrian, is there any other issue that this could be within final cut? I setting or something? I addressed the codec issue and it doesn’t seem to be fixing it. I even went back and opened some older projects that I never had a problem with and even those canvases are black and white. Any thoughts?
Shane
Shane Trowbridge
July 22, 2010 at 6:02 pmJerry, I was wondering if you had any input. I properly adjusted the codecs and I am still having the black and white canvas issue. I even went back to some old projects that never had a problem before and even those canvases are black and white.
