Activity › Forums › Apple Final Cut Pro Legacy › Best way to do this? AVI to edit in FCP
Posted by Future Man on January 19, 2007 at 3:50 pmHi Everyone,
Ive been searching threads and Google but Im not sure I have a good answer to this so I really appreciate any advice.
I have an AVI that I recieved. It’s of my band performing. What I want to is put it in Final Cut Pro HD 4.5 and edit it. Basically it has other bands in the footage I want to get rid of and also I want to fix some audio issues.
What is the best way I can get an AVI into my version of Final Cut?
p.s. I also have Quicktime 7.1.3 Pro
Thanks for any advice!
(Mr.Davis)Future Man replied 19 years, 3 months ago 4 Members · 14 Replies -
Daniel5000
January 19, 2007 at 5:51 pmDoes the AVI open on the Mac in QuickTime?
If it does then check the AVI resolution and frame rate, if it matches you editing setup, then you can export from QuickTime Pro to the desired FCP codec/playback setting.
If it doesn
Rich Rubasch
January 19, 2007 at 5:54 pmMPEG Streamclip…..squared5.com
Will convert AVI to any QT format you choose.
Rich Rubasch
Tilt Media -
Future Man
January 19, 2007 at 7:45 pmHi Everyone,
The file will not play in Quicktime… it is 44.1MB.
I tried opening it with MPEG Streamclip and it only plays the audio.
It does play fine in VLC.
Any thoughts?
Thanks so much.
Gustavoz
January 19, 2007 at 10:32 pmuse compresor to change it to the format you want.
Ijust did it in la last job -
Future Man
January 22, 2007 at 10:00 amHi Everyone,
I’m still struggling to do this. I don’t own compressor and even if I wanted to upgrade I would need to order it and have it sent to me (because I am in Germany now)… and considering nothing else has worked I’m reluctant to spend the $200.
Strangely I even tried SnapzPro to record the video window but it came out all mangled… why?
I really want to have this AVI converted to something I can edit and use.
Thanks again for any advice!
Daniel5000
January 22, 2007 at 4:21 pmSorry for the double post everyone
If QuickTime on the Mac can
Daniel5000
January 22, 2007 at 5:37 pmHello
Alternatively you can try downloading and installing something called Perian_0.5
from versiontracker.com.It says that it will allow QuickTime to open a lot of types of AVI. If it works then go back to the suggestions listed in previous posts for exporting.
Please be aware that I haven
Future Man
January 22, 2007 at 6:59 pmHi Guys,
We are getting somewhere I think… I installed Perian and now Quicktime plays the file! What format should I export it as so FCP will be able to read it? I tried exporting it to .mov but it didnt work… it did the export, then the file was called sample.mov and opened in Quicktime but when I tried to import it into FCP it have me a File Error… any ideas here?
Again… thanks thanks!!!
Future Man
January 22, 2007 at 7:20 pmOk… by exporting from Quicktime in .mp4 I was able to open it in FCP!!! Now the quality is low… anyone have any advice on how to match the quality and size of the original?
Thanks thanks!
