Activity Forums Apple Final Cut Pro Best way for save and archive with FCPX
  • Best way for save and archive with FCPX
    Posted by Fredy Schwerdtner on August 7, 2015 at 1:43 am
    Hi Shane.
    I was walking around and touched your post. I’m back tô the industry after 14 months away. It is só interesting to realize that a lot can change in a so short time … lol
    Well, I’m working with FCPX ( I love it) and I’m in a job that I will have tô digitalize 53 old tapes (VHS and VHS-C) and mix their material with some graphics and then burn DVDs and also prepare the final files tô be archived in an external HD. Since I am capturing the tapes with an old VCR via a kind of a “bridge”, the Canopus Device ADVC 300 with FCPX optimizing the files as PRORES. It makes easy for editing and when I export it, I do it as it is (PRORES / FULLRES) to compress the file with Apple Compressor as MPEG2 and AC3 to make the DVDs.
    Now, I was thinking in save and archive the final projects as PRORES, as it come from FCPX, or make a H264 out of them to save in the external HD.
    What do you think about it ?
    Thanks in advance.
    Fredy.
    iMac 2.7 GHz Intel 4 Core i5
    16 GB memory
    MacBook Pro 17″
    2.5 GHz Intel Core 2 Duo
    6GB 667 MHz DDR2 SDRAM
    OS X 10.7.5
    FCPX 10.0.8
    Robin S. kurz replied 11 years, 1 month ago 2 Members · 1 Reply
  • Robin S. kurz
    August 7, 2015 at 11:32 am
    [Fredy Schwerdtner] “to compress the file with Apple Compressor as MPEG2 and AC3 to make the DVDs.”
    What are you using for muxing and output that accepts those file types?
    [Fredy Schwerdtner] “Now, I was thinking in save and archive the final projects as PRORES, as it come from FCPX, or make a H264 out of them to save in the external HD.”
    The primary difference obviously being file SIZE. If size is not a concern, simply go with ProRes. Otherwise I highly doubt that H.264 could make anything worse with VHS. Even H.264 is bound to retain all of its gory details without a problem. 😀
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
