Activity Forums Adobe Premiere Pro Best HDD Configuration ?
  • Best HDD Configuration ?
    Posted by Davis Lanthripe on August 19, 2008 at 12:54 am
    I got bit of a problem…
    After waiting a few years to upgrade my computer I finally will be able to build what I want, not just what I can live with.
    WHen it comes to Hard Drive Configuration, I just do not know which way to go.
    Here is what I am thinking….
    I know Adobe says the HDD should be in RAID 0, but that does not seem to be the b est way to go. I think I should have one HDD for software, one for video/audio, one for preview/scratch.
    So it is like this…
    1 – 320G Software
    2 – 500G ( 1TB ) RAID
    1 – 320G Scratch
    This is better than all on a RAID Aray. Right ???
    I am a IT specialist for a school district so I know alot about this stuff. That don’t mean I know everything. Getting this perfect the first time is what I have spent most of my time researching. That might be my downfall, too much shopping and researching into the ” perfect ” system.
    Thanks for the input!!
    Davis
    David Dobson replied 18 years, 1 month ago 5 Members · 8 Replies
  • 8 Replies
  • Harm Millaard
    August 19, 2008 at 9:21 am
    What is “Best”? It is not difficult to come up with better HDD configurations, but it is always a matter of balancing cost and benefit. Your suggestion makes perfect sense if the storage capacity is sufficient.
    If you want best, consider a 128 GB OCZ Core SSD as a boot disk for OS & programs.
    For media, consider 8 x 1 TB WD Caviar Black disks in Raid50.
    For project/scratch consider 4 x 1 TB WD Caviar Black disks in Raid3.
    Make sure that all 12 disks are hot swappable and use an Areca ARC 1680iX-12 controller with BBM and 4 GB DDR2 ECC cache.
    Harm Millaard
  • Vince Becquiot
    August 19, 2008 at 7:27 pm
    I would be more worried about making that 3rd drive a RAID backup, rather than a scratch disk. And ideally, it would be as big as the RAID itself (in your case I would say 750 Gigs would be fine)
    Only keep the files that need RAID speed on the RAID drives.
    Vince
  • Davis Lanthripe
    August 19, 2008 at 7:31 pm
    Good point Mr. Millaard,
    I should rephrase, ” Best for my budget ”
  • Davis Lanthripe
    August 19, 2008 at 7:33 pm
    OK, So you are saying I would be better to have two RAID’s ?
    And only using one to back up the other?
    Thanks for the input.
  • Ricardo Reyes
    August 20, 2008 at 1:55 pm
    Although the Areca ARC-1680ix-12 is the latest and greatest SAS/SATA RAID Controller. The ARC-1231ML SATA RAID Controller is still the best performance choice when using 12 SATA drives. The ARC-1680ix-12 really outshines the ARC-1231ML in SAS drive environments only.
    Raid is meant for data redundancy. Always make a back up of your data!
  • Harm Millaard
    August 20, 2008 at 4:07 pm
    The main difference is the IOP348 versus the 341 and the supported cache. That makes the 1680 series significantly faster than the 12xx series.
    Harm Millaard
  • Ricardo Reyes
    August 20, 2008 at 4:16 pm
    Our test have shown better performance with the ARC-1231ML in SATA environments when compared with the 1680 SAS Controller series.
    The IOP341 is just designed and optimized for SATA drives, than the IOP348 chipset.
  • David Dobson
    August 20, 2008 at 11:50 pm
    Depends on what you plan to edit.
    I don’t do uncompressed SD or HD – all DV, DVCProHD, HDV – I think XDCAM will work on SATAII (3GB/s) drives as well. So my solution is now that I use the NexStar Hard Drive Dock and put the video and the scratch on a drive I plug into that. Swapping projects is as easy ejecting one hard drive and inserting another. Back up is as easy as ejecting the drive and putting it on a shelf.
    With SATAII drives at $80 for 500GB, it is finally clearing away all the the plugs and drives in my work area. The NexStar Dock is $40 bucks and I am going to have 4 of them shortly. Just get a mother board with enough SATAII slots on it.
    I might get a RAID someday for more consistent speed. Also if you don’t keep editing off the same drive, crashed drives are less likely so I don’t need the back up either.
    All the software is on the C:\ Drive …
