Activity Forums Adobe After Effects Best codec to Render HD/SD
  • Best codec to Render HD/SD
    Posted by Pieco on June 28, 2007 at 4:57 pm
    it seems that no matter what codec I use to render any graphics that include shot footage, I never get the same quality as the original. The footage always seems to render a bit grainier and more contrasty. I usually use QT Animation for the majority, but tried other types of files with no great results. The objective is to render footage out of AE that is a clone of the source footage. Any suggestions?
    Pieco replied 19 years, 2 months ago 3 Members · 4 Replies
  • Steve Roberts
    June 28, 2007 at 5:15 pm
    Use Animation, 8-bit uncompressed, or 10-bit uncompressed. Those are lossless.
    Anything else recompresses the footage in a lossy manner, as you’ve seen.
  • Kevin Camp
    June 28, 2007 at 5:18 pm
    the yuv to rgb conversion is the gotcha here. it seems to be impossible to go from yuv to rgb and back to yuv and have it look exactly the same.
    what seems to be your best bet is to try and export your footage from your nle with a conversion from yuv to rgb to a lossless or uncompressed format. take that into ae, render back to the same format. import that into your nle converting the rgb to yuv and see how close you are. (unfortuanately, the nle will recompress the lossless/uncompresseed footage back to the compression used to capture the original, so some quality loss will occur).
    you can also compare that to using ae to do the yuv conversion. take your yuv footage, choose interpret footage from the file menu, click the check box for expand itu-r 601 luma values. drop that into a comp, then add a levels adjustment with black output set to 16 and white output set to 235. render and import into you nle (no conversion for color space) and compare.
    choose which looks best to you, and use that workflow, but i think you’ll always get some shift and slight quality loss.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Pieco
    June 28, 2007 at 5:40 pm
    Thank you. For Graphics, the animation codec is what I use. But it still does something to the footage when I export.
  • Pieco
    June 28, 2007 at 5:42 pm
    thanks for your explanation. I will have to try the process that you describe. I never thought about the yuv to rgb conversion. thanks for your time, i appreciate it.
