Activity Forums Storage & Archiving Best Alternative to ISIS or Unity for Small AVID Production House
  • Best Alternative to ISIS or Unity for Small AVID Production House
    Posted by Vikas Dharia on April 27, 2016 at 7:23 am
    Hey guys
    Right now I have 5 MAC PRO EDIT BAYS running on AVID MC 7 on 10.7.5, that are connected to a Unity 5 through Fibre cards and a ISIS 5500, although the ISIS is just one engine and the Unity is a maxed out Unity 5 with lots of racks.
    I want to upgrade to El Capitan and MC 8.5 but the Unity holds me back from that, I also don’t work in uncompressed, I always work in DNX 145 or Pro Res and even down the road if I worked in 4k it’d be a compressed version.
    I’m trying to find the best storage solution that still supports AVID Volume locks and bin locks.
    So far I’ve found Sonnet’s RX1600 FIBRE and Terrablock, the other choice I found was using SANFUSION.COM ‘s software to allow an XSAN server to work like the Unity when AVID Mac’s are connected even on MC 8.5 and El Capitan. The RX1600 is $15k per 96TB and I’m thinkign I can connect that through fibre and it already allows bin and volume locking on the AVID end.
    What do you guys suggest? I need like 200TB of space so the AVID hardware route is too pricey but I need 8 edit bays to be able to access it just like the Unity allowed.
    My preferred option is to have one central server, 200TB, running Ethernet Gigabit connections to my edit bays, but Fibre will do too just its more pricey to get up and running.
    Thanks let me know!
    Roger Beck replied 10 years, 1 month ago 10 Members · 12 Replies
  • 12 Replies
  • Bob Zelin
    April 28, 2016 at 3:46 am
    You can use a Facilis Terrablock 8D or an AVID Nexis.
    Unity ? Are you kidding me ? That product has been discontinued for countless years now. And the AVID and Facilis are both CHEAP.
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
  • Rainer Wirth
    May 4, 2016 at 12:55 pm
    I would go for the sonnet with xsan server.
    But for 200 TB you need a sonnet 1600 extension (with the sonnet fibre together)
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
  • Tim Ward
    May 6, 2016 at 2:35 pm
    Studio Network Solutions EVO shared storage provides native Avid Media Composer project and bin sharing at an affordable price. This is a very simple set up that does not require any other servers or software. To an editor it looks just like they are accessing an ISIS.
  • Bob Zelin
    May 12, 2016 at 9:25 pm
    Rainer –
    exactly what kind of incorrect advice are you giving here.
    Apple XSAN server cannot support AVID shared storage support, or AVID Bin locking.
    Exactly where do you get your information from.
    You can use the new AVID Nexis (which has replaced ISIS), or a Facilis Terrablock 8D if you want to spend very little money, or solutions from Studio Network Solutions, Tiger Technologies, Small Tree, ProMax, EditShare, Archion. Please don’t give out incorrect information. I love Sonnet – I use their products all the time, in almost every installation, but this product with XSAN cannot support multiple seats of
    AVID Media Composer. It is the wrong product for this application.
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
  • Alex Gardiner
    May 14, 2016 at 11:07 am
    There are lots of solutions to AVID bin locking, even some software only like Quadrus.
    This is our offering, which is pretty new and works with any generic SMB/CIFS/AFP based drive (win & mac compatible):
    https://indiestor.com/product/mimiq/
    alex@indiestor.com
    Open Source Shared Storage
  • Neil Sadwelkar
    May 15, 2016 at 4:12 am
    I’ve seen a few old Avid Unity setups where the editors are simply not using the Avid bin and project sharing facilities that only unity provides. Instead there are different editors working on different projects seldom sharing any sequences. If that is your workflow, then a Unity/ISIS is overkill. Any shared storage will work fine.
    ISIS or Nexis, or some other Avid capable solution will always be costlier than a standard shared storage. At the moment a Nexis Pro with 16 TB shared storage runs £ 10,000 (US$ 14,000). Plus about £ 1000 ($1400) for the switch. If you’re in a country with import duties, these will run up the price by another 25-30% in some countries.
    So, examine the editing workflow, check out the extent of sequence sharing. If all 8 can work off separate partitions with the occasional copying of media from one to the other, then just a shared storage will do fine. And for the same price as a Nexis you’ll get two to three times the disk storage. Alternately, you could even do a ‘hybrid’ with critical shared media off a Nexis Pro with only 32 TB storage, and the remaining 170 TB of standard shared storage partitioned one per user with only unshared media on it.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • Brennan Mcbride
    May 24, 2016 at 5:49 pm
    Alex was kind enough to let me demo Mimiq and it was spot on. I was using it in a very simple shared storage environment and preformed better than expected. All in all a great product. While I certainly could have benefited from 10Gb, the two systems sharing media and the project with prores 422HQ clips AMA did well enough on a 1Gb network.
  • Andrew Proude
    June 4, 2016 at 5:21 am
    Why not just setup a 200TB NAS as nearline (for hires media),
    then use your ISIS for offline (DNxHD36), when you’re edit is locked, upres/conform to your originals.
  • Trevor Cable
    June 16, 2016 at 4:13 pm
    I’ve had a fair amount of experience with Unity and Terrablock and just this week purchased the new Nexis E4 with 120TB. It was nice to see the cost for 120TB from Avid finally be at a price that I think is fair (approx. $60K without without switch). However, I did have an opportunity to test San fusions product and was really blown away. If you have someone on staff that is tech savvy with Unix you could build a system for far less than any other system. I had a 24TB retired server sitting on a shelf so we put FreeBSD on it and within an hour I had a multi seat Avid bin locking system using San Fusion. They don’t put any software on the server itself, it’s all done through the client software. I was very impressed. The product worked well and when I had a recommendation for the client software the support staff took interest and I believe it’s now part of the software. The only reason I chose to go with the Nexis over San Fusion is that our company requires 24/7 uptime. This means for support I only want to call one company and not have anyone suggest it’s not their problem (switch, server, OS, etc).
    Anyway, my 2 cents.
    -Cablet
  • Trevor Cable
    June 16, 2016 at 4:15 pm
    Oh, and as a side note my previous thread, if your company depends financially on your edit bays working then seriously consider spending the money the Nexis. You really do get what you pay for when everything is considered.
