Activity Forums Apple Final Cut Pro Legacy Batch Capture? I want to Log & Transfer
  • Batch Capture? I want to Log & Transfer
    Posted by Robert Due on September 14, 2009 at 7:13 pm
    Hello all. I am using Workflow #2 from the RED FCS Whitepaper, however, the original files that were used in the offline were processed through RED Rushes. It was also edited out of house (I am doing the color grading). I prepped the sequence (removed all non RED shots), flattened down to one V track, removed all attributes, etc. The problem is when I go to ingest the Native RED files it doesn’t go to Log & Transfer. I get the Batch Capture screen.
    Is this from creating the files in RED Rushes? I opened L & T and mounted the RED drives.
    Help!
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
    Rich Moos replied 13 years, 5 months ago 8 Members · 12 Replies
  • 12 Replies
  • Shane Ross
    September 14, 2009 at 7:23 pm
    When you recapture from tapeless formats it launches BATCH CAPTURE…but then opens the LOG AND TRANSFER interface…
    Shane
  • Robert Due
    September 14, 2009 at 7:29 pm
    It is just opening Batch Capture…expecting tapes.
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
  • Shane Ross
    September 14, 2009 at 7:33 pm
    CLICK OK at that point. I have done this more than a few times. You choose BATCH CAPTURE, and that window opens up..but after clicking OK it then opens up Log and Transfer.
    Shane
  • Shane Ross
    September 14, 2009 at 7:34 pm
    Wait…it might NOT if you didn’t use L&T in the first place.
    I’ll shut up now, as my RED experience is nil.
    Shane
  • Robert Due
    September 14, 2009 at 7:37 pm
    I appreciate the help. That is what I thought as well (I have gone through BC and L&T opened up). I am trying to avoid the process of ingesting all the clips and then manually editing them in. (18 minute short film)
    Anyone know a way around this?
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
  • Shane Ross
    September 14, 2009 at 7:57 pm
    Ah…yeah, with FCP 6, it will reinjest the FULL clip, even if you only used a small part. FCP 7 fixed this. With FCP 7, when you media manage and make the smaller clips, and then reimport, FCP will only import the sections used.
    Shane
  • Jan Russell
    September 23, 2009 at 1:23 pm
    I am having the exact same problem except my film is 70 minutes long and I definitely do not want to do it manually.
    My offline Apple ProRes files were encoded in RedRushes.. now I’m trying to go back to the original RED files using log and transfer. I have made my seq offline and now trying to batch capture but it brings up the batch capture window and not the batch log and transfer.. HELP!!!
  • Ron Smith
    February 19, 2010 at 8:48 pm
    yes I am doing the same thing.
    Log and transfer is what is suppose to open, but log and capture opens and it stops there.
    did yu ever figure it out
  • Aaron Goddard
    March 22, 2010 at 6:31 pm
    Same problem here. Appears to be related to FCP 7. Anyone find a good solution?
    Aaron Goddard
    Evolve Post
  • Stan Jackson
    May 22, 2010 at 12:39 am
    i’m dying for a solution to this. same deal here…
    transcoded w/ redrushes, now we’re stuck…
