Activity › Forums › Apple Final Cut Pro Legacy › Batch Capture? I want to Log & Transfer
Rich Moos replied 13 years, 5 months ago 8 Members · 12 Replies
David Valiquette
July 9, 2010 at 4:18 pmDid someone find a solution? i’m having the same problem…
Cheers!
Rich Moos
April 8, 2013 at 9:12 pmLong time reader, first time poster. I manage a med/small facility. We have 9 FCP7 seats connected to an EditShare with 18 TB effective storage. In the recent past we had been working full rez on all projects form start to finish. Rapidly expanding demand and a move from EX1 acquisition to C300 acquisition has forced us to an offline/online workflow. A drag yes, but it’s the way we used to do it right?… before tapeless.
All master footage is brought in through Log & Transfer. We process the master footage in Media Manager to Offline RT with the Recompress method. Cut, then prep sequences in Media Manager with the create offline/delete unused media/with handles method. Open the new project that Media Manager made and launch Log & Transfer, load original media from archived cards and click batch capture. Instead of processing in Log & Transfer, FCP keeps opening Log & Capture as if it was looking for a tape. This happens regardless of the OS or hardware.
I have read the all of the very few posts about this error that are out there. I have also tested and retested multiple ways of Media Managing the material. I have yet to discover a solution. I’ve read unconfirmed suggestions that there is a problem with EX1 footage and Offline RT files, but this is happening with my C300 footage as well. I’m suspecting that I will run into this with every tapeless format. This seems to have affected Red users in the past who did not use L&T to handle their footage. The work around was to use Clipfinder. I thought that might be a work around for us as well, but that option is no longer available as the developer has stopped further development and support of that utility.
The process works fine when we use flavors of ProRes. However, we went with Offlline RT instead of ProRes Proxy because when we assessed overhead, we determined that we would exceed the capacity of our current architecture within a year or so given the current demands. Our work requires us to have access to a large volume of archive material as well as current material.
Based on the lack of posts about this and the age of the posts that do exist, it appears that very few people are offlining now days, or the problem was solved and folks just moved on. But I know that there are those out there in similar situations. Any advise or opinions are extremely welcome.
