Activity › Forums › Adobe Premiere Pro › AVOID 12.1 update!
AVOID 12.1 update!
Posted by Dan Powers on April 5, 2018 at 5:58 pmIt has big issues!!
Todd Hallam replied 8 years, 4 months ago 11 Members · 18 Replies -
Dan Powers
April 5, 2018 at 6:06 pmFiles with alpha channels are coming in corrupt. From Support “This is a bug that we have logged for the Premiere pro, it is happening with the PNG files as well as any mov file with the transparency (alpha channels) the workaround here is to revert to the older version”
Robert D’alexis
April 5, 2018 at 7:27 pmWorks fine here with a .mov file using the Gopro Cineform 12-bit with alpha codec.
I am on Windows 10 and I can assure you that I have no issue encoding and importing the above-mentioned file.
I suggest you try similar files and report back. -
David Busse
April 5, 2018 at 7:53 pmAgreed! Mine wouldn’t even open. After 1.5 hours of troubleshooting, uninstalling, reinstalling I was able to get back up and running by downgrading back to 12.0.1
Video Producer/Editor
https://cidesigninc.com/ -
Todd Hallam
April 5, 2018 at 8:14 pmAgreed! Major slowdowns – and Adobe Typekit keeps trying to resolve a conflict even though I have it shut off in CC. Spinning beachball trying to resolve that and xml imports given me lengthy beachballs. HUGE timewaster!!!!!
Todd Hallam
SideshowFX
http://www.sideshowfx.net -
Christopher Paul
April 5, 2018 at 8:53 pmYup. Another issue is that the search fields no longer work- greyed out.
Robert D’alexis
April 5, 2018 at 10:38 pm[Dan Powers] “it is happening with the PNG files as well”
I have been testing PNG files and I can report that they work just fine in an HD timeline.
Maybe your issues are Mac-related as I am on Windows 10.
Anyone else care to chip in? -
Robert D’alexis
April 5, 2018 at 11:03 pm[Christopher Paul] “Another issue is that the search fields no longer work- greyed out.”
They work just fine here.
Ann Bens
April 6, 2018 at 9:01 amTry this:
Modify -> Interpret Footage.
Under the Alpha Channel category, select “Conform Alpha Premultiplication To:
And also select the box: Premultiplied Alpha———————————————–
Adobe Certified Expert Premiere Pro CS2/CS6/CC
Adobe Community Professional -
Ann Bens
April 6, 2018 at 9:26 amThis help a user:
Dan Pearce
April 6, 2018 at 9:44 amTwo hours in and so far…
It wouldn’t open, had to delete the “Typesupport” folder to get it working (which maybe explains the following problems)
Wrench icon (timeline display settings) doesn’t work!
The Editing Mode drop down in sequence settings doesn’t work!
Format drop down in Export Settings doesn’t work!
Anyone else having these issues!?
Not impressed ]
Dan
