Activity › Forums › Adobe Premiere Pro › AVOID 12.1 update!
Oliver Peters
April 6, 2018 at 1:27 pmIs this a Mac or Windows issue? If so, are you running the latest OS? So far, I’ve updated at least 8 Macs (various models) without issue, other than a few minor glitches here and there. Nothing outside of the ordinary.
– Oliver
Oliver Peters – oliverpeters.com
David Busse
April 6, 2018 at 2:58 pmOliver,
I am having this problem on a 2012 iMac and a 2014 iMac. On a 2013 MacBook Pro it was working fine. We are now running all on 12.0.1Also, FWIW had a problem where XML from Premiere 12.1 from our laptop wouldn’t work in 12.0.1 so I sent the XML to Premiere 2017 and it opened in there then I was able to update that project to 12.0.1
Video Producer/Editor
https://cidesigninc.com/ -
Dan Pearce
April 6, 2018 at 3:09 pmMac Pro (Late 2013). It’s a production company who are still running 10.11.6 because of a server requirement.
Exported an xml and rolled back to 12.0.1 as I had work to do.
Michael Sacci
April 9, 2018 at 5:44 pm“the workaround here is to revert to the older version”
How does one revert to 12.0.1? there is no way to not have 12.1 overwrite the older 12 versions.
Michael Sacci
April 9, 2018 at 5:49 pmNever mind, I see that it has 12.0.0 listed in the previous versions drop down.
Don Daedalus
April 18, 2018 at 5:54 pmMASSIVE PROBLEMS on Premiere 12.1:
-.mov with alpha channels flicker, glitch
-Some .mp4 videos appear upside down
-Exporting FCP XML, fail upon importing to 12.0Downgrading to 12.0 has problems also:
-Exporting .H264 renders “Error compiling movie -> Import Error -> importer returned bad result
-importing XMLs from 12.1 creates an error
-Starting a new project and dragging XML has some results, but creates problems upon exporting
-AME 12.0 fails
-Missing audio filter/video filter depending on whether AU or AE are upgraded/downgraded.At least Adobe is admitting these problems exist, (search tag ‘12.1’)
https://forums.adobe.com/search.jspa?q=12.1Macbook pro 2017, High Sierra, 16GB ram, Intel 3.1 i7
-DHPD
Alan Okey
April 19, 2018 at 5:44 pmPremiere Pro CC 12.1.1 has been released.
Release notes:
Bugs fixed in April 2018 (version 12.1.1) release
The following bugs are fixed in version 12.1.1 release of Premiere Pro:
· Fixed a crash on launch in some cases when loading Cool Type fonts (these fonts are prevented from loading.)
· PNG files containing Alpha are correctly displayed with the default interpretation of Straight Alpha.
· In some PNG frame sequence exports, frames no longer get mixed together (superimposed).
· Application no longer hangs if you quit it after playback of Sony F5 RAW files. -
Todd Hallam
April 19, 2018 at 8:41 pmGreat – still hasn’t fixed the biggest issue of all mp4 media reading as offline though.
Todd Hallam
SideshowFX
http://www.sideshowfx.net
