Activity Forums Avid Media Composer AVID import settings
  • AVID import settings
    Posted by Pratul Gaikwad on March 25, 2010 at 1:41 pm
    I am bit confused about the Alpha channel options availiable while importing the media in avid…
    How exactly this option helps/ what difference it creates ?
    How it helps for croma keying ?
    Basically I have gone through the AVID help section but couldnt understand the basic idea about Alpha Channel , What exactly alpha channel is?
    As you see i couldnt understanding it even after reading the AVID help, indepth explaniation will be more appreciated ..
    David Lewis replied 16 years, 4 months ago 3 Members · 3 Replies
  • Jandle Johnson
    March 25, 2010 at 2:46 pm
    An alpha channel in an image file contains transparency information to tell the program which part of an image should be opaque, such as a logo, and what should be discarded (or keyed out)so that the video layers below can be seen, such as the green in a greenscreen shot. An alpha channel is based on luminance and if you looked at it by itself it would be a black and white image usually with white areas showing 100% opacity, and black showing transparent areas. Areas of grey would represent varying degrees of opacity. The alpha channel of a logo to be keyed over a background would appear as a white shilouette of the logo shape surrounded by black. If it had a drop shadow that would appear as a fuzzy grey area around the logo shape.
    The alpha import settings in the avid are used when you are importing a still or video file that has alpha information created by the application used to generate the image such as a logo from photoshop or an animated logo or greenscreen key from after effects. These settings are telling the avid to 1. look for alpha info, and 2. how to use it. The avid is unusual in that it interprets alpha info the opposite of every other application. It sees black as opaque and white as transparent. Therefore, it is necessary to check the “invert alpha” option when importing anything that is created by another application and/or not rendered using an avid codec. Once imported, the file with your “fill”, ie. a logo, is placed on V2 and the background placed on V1 to complete the composite.
  • Pratul Gaikwad
    March 25, 2010 at 6:50 pm
    thanks Jandle … I did get an idea as to what may be happening .. i think I need to try an import some greenmat footages and follow what you said …
    Big thanks for elaborate explanation
  • David Lewis
    April 19, 2010 at 9:01 am
    Thanks for the explanation… I too have not always understood the issue of Alpha… I assume if I have a logo in jpeg form and I want to give it an opaque background so i can key the logo, I could create the “alpha” in something like Photoshop? Am I correct??
