AVCHD just stopped working in FCP7? (then works again, then doesn’t?)
Hi y’all,
I have run into an issue that is confounding me. I hope someone here can offer some advice.
I have some AVCHD footage I need to import into FCP7. I copied it over from the memory card onto a hard drive (yes, I copied the entire directory structure), but when I try to mount it I get the dreaded “contains unsupported media or has an invalid directory structure” message.
Here’s the thing: I was able to mount this footage two days ago, and I haven’t touched this folder since then. (I have already verified the drive in Disk Utility, just to check)
I notice that this was true of another AVCHD I imported a few days ago, then went to re-import some stuff and was given the “unsupported media” message. But now this footage once again mounts fine.
This seems to be very strange behavior and I can’t find a reason for it.
Does anyone have any idea what might be going on, or a suggestion on what to check into? Any advice would be super helpful. Thanks!
