Activity › Forums › Apple Final Cut Pro Legacy › Audio – used on board and sennheiser mic during recording – capture issue w/ FCP
Posted by Dog Food on August 3, 2006 at 6:08 amHI!
I used a Sennheiser shot gun MIc for channel 1 and the on board mic for channel 2 on my Panasonic 100B. During logging and capture I can hear the channels are different and correct.
But when I capture I am getting a MONO single track(1) in the FCP time line, viewer, and canvas. I have tried to adjust the “clip settings” in the “log and capture” window and have had zero sucess.
I have captured more than 3000 tapes in the past years and I have never had this problem. yikes
I need 2 seperate audi tracks yet I am only getting ONE. What am I doing wrong?
Any help would be greatly appreciated!I am assuming the problem is with capturing and not with the original recoding since I can hear the different channels during logging.
thanks
: )Jeremy Garchow replied 20 years, 1 month ago 4 Members · 16 Replies -
Renjith
August 3, 2006 at 9:30 amTry capture in mono mode. Un lock ur sterio mode in capture window.
Thanx
Renjith
Bouncing Account needs new email address
August 3, 2006 at 1:11 pmThe first thing to always try is to Quit FCP, Restart the Mac, Open your FCP project and try again.
Next:
THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
“Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”Click the following link for instructions.
https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
There are versions for FCP (Pro) & FCE (Express) and a new one for FCP 5.Download these free Apple Scripts at
https://fcprescue.andersholck.com/
or
https://pistolerapost2.com/fcprescue/This is one FCP tip that has helped in solving hundreds of “odd” problems.
Dog Food
August 3, 2006 at 3:01 pmOK.
1. I throuh away preferences
2. I captured a sample clip using the “NOW” capture mode…. using the “MONO” setting in the “log and capture” / “clip setting: window
the clip captured perfectly.. jus the way i wanted it to… when I looked at it in the viewer it had two tracks!
THE problem is this.. All of my clips were logged in the “MONO” setting, and yet when I capture these clips using the “batch capture” they only come back with 1 rack as opposed to when I use capture “now” they are in stereo..
YIKES..
any thoughts?
Jeremy Garchow
August 3, 2006 at 3:46 pmAre you capturing straight form the camera or though a deck and capture card? What easy setup are you using? Don’t use capture now, we can fix the problem.
Dog Food
August 3, 2006 at 4:52 pmThanks Jeremy,
I am caturing through a camera PV-GS32 (picked up at costco).
I used capture “NOW” as opposed to “Batch Capture” as a test. Of course I was nervous that my problem was with my original recording… but when I used capture “NOW”, I got 2 seperate tracks.
I am using a custom set up. I shot in 16:9 squeeze/24p mode. My settings are 16:9/anamorphic.
Thanks for the help. I am eager to get past this hump.
Dog Food
August 4, 2006 at 9:21 pmWell,
I found the error… I logged the tapes with the “audio format” set at “MONO” (in the “log and capture” – “clip settings” window) ..
Now heres the problem..
when I go into the “BIN” it will not allow me to change the audio format of the clips.. neither the captured nor the offline clips.
How do I change the audio format in the BIN of 2000 logged clips..??????? When I right click it only give me the options of
A1
MONO MIX
B1I need
CH 1 + CH 2thanks for your help!
Jeremy Garchow
August 4, 2006 at 9:29 pmFor the offline clips, you can select them all in the browser, right click (or control click if you don’t have a two button mouse) and select clip settings from the drop down menu and change the audio format from 1 channel mono to two channel either dual mono or stereo. For the ones you have already captured, you will unfortunately need to recapture. You can take them offline and do the above method, or you can select them all, control click and select batch capture, UNCHECK used logged clip settings, and set up the logging preferences for dual mono or stereo.
Good luck.
Jeremy
Dog Food
August 4, 2006 at 11:35 pmthanks jeremy,
I think you met right click and go to “item properties” and then “format”
correct..?
I tried this many times and FCP will not give me the option to change the audio format to anything other than
A1
MONO
A2…
this is killing me..when I re-log a test clip and have the “clip settings” at “CH 1 + CH 2” and then capture the test clip… I get the audio exactly the way i taped it.. 2 seperate tracks
There has to be a way to change the audio format besides re-logging 2000 clips!!
I have even tried copying the clips and putting them in a new project.. NADA!!
yikes
any other thoughts?
Jeremy Garchow
August 5, 2006 at 12:02 am[dog food] “I think you met right click and go to “item properties” and then “format”
correct..?”
Nope, clip settings. Right above item properties.
