Activity Forums Apple Final Cut Pro Legacy Audio-Levels, Relative and Absolute
  • Audio-Levels, Relative and Absolute
    Posted by Alexander Kallas on August 5, 2013 at 11:14 pm
    Hi all,
    I cannot get this to work after rubber-banding the audio in FCP7. The audio line reverts to straight line
    after applying the levels modifier. Frustrating, Kevin McAuliffe’s article does not seem to apply!
    Cheers
    Alexander
    Alexander Kallas replied 13 years ago 2 Members · 4 Replies
  • Rafael Amador
    August 6, 2013 at 1:12 am
    What’s the problem Alex?
    If you have already animated (key-frames) or adjusted your audio, you have to check RELATIVE, in order to keep that animation.
    If you chose ABSOLUTE, the whole audio will be set at the absolute value you have set.
    rafael
  • Alexander Kallas
    August 6, 2013 at 1:56 am
    Thanks Raf,
    I want to adjust all the separate clips in the sequence simultaneously.
    Each clip has been rubber-banded to a greater or lessor extent.
    Cheers
    Alexander
  • Rafael Amador
    August 6, 2013 at 6:22 am
    [Alexander Kallas] “I want to adjust all the separate clips in the sequence simultaneously.
    Each clip has been rubber-banded to a greater or lessor extent.”
    Then select the whole tracks and apply the RELATIVE gain option.
    The rubber banding will be kept and gain will be added or reduced up to the value you set
    rafael
  • Alexander Kallas
    August 7, 2013 at 5:21 am
    Got it now, thanks Rafael
    Cheers
    Alexander
