Activity Forums AJA Video Systems Audio issues with CS6 Kona 3
  • Tom Daigon
    June 7, 2012 at 10:02 pm
    AJA tech support is the best.
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.7.3
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digital / Areca 8tb. raid
    Kona 3
  • Robert Brown
    June 8, 2012 at 8:14 am
    [Jim Watt] “They had no suggestions on what was causing the Kernal Panic I was getting while trying to change audio hardware preference and also while in the Mac audio preference going from line input and output to Kona card.
    thx…jw”
    What are you getting for Kernal Panic. I’m getting a bunch “Sorry but Premiere has experienced a serious error and must shut down”. I’ve had 6 or 7 of those in the last couple of days. Seemed to start after I added a noise reduction plugin. Don’t know if that means anything.
    Robert Brown
    Editor/VFX/Colorist – FCP, Smoke, Quantel Pablo, After Effects, 3DS MAX, Premiere Pro
    https://vimeo.com/user3987510/videos
  • Tom Daigon
    June 8, 2012 at 5:03 pm
    Sounds like its systemic to your computer. Im cutting a music video now. Just the audio track. Clear as a bell on the Kona 3. See system configuration below.
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.7.3
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Jim Watt
    June 10, 2012 at 9:03 pm
    I’ve seen a few of the Premier errors, but the Kernal panics were full blown semi transparent box in middle of screen telling me I had to restart. Repairing permissions seems to have solved all of the issues however. A least for now.
    Producer/DP, HD series, “Discoveries…America”, “Discoveries…Ireland”, “Discoveries…Spain”,
    “Discoveries…Argentina”, Discoveries…India”, “Discoveries…Asia”, “Discoveries…Africa”
  • Richard Cooper
    June 20, 2012 at 8:18 pm
    I fixed these problems (99% of the time) by calling AJA Support. He had me not only set the OSX system preferences output to “optical digital out” but also the INPUT to “optical digital in”. He said BOTH need to be set this way. Then in CS6 audio hardware preferences set to “built in output”. Then set the CS6 Playback default player to “Adobe Player”and the audio device to the “AJA Kona(your flavor here)”
    One final thing is that he had me do is delete my AJA preferences in the “user>library>preferences folder. Basically all of the”com.aja.xxxx” files.
    Once I did all of this and did a reboot everything has worked very nicely.
    Richard Cooper
    FrostLine Productions, LLC
    Anchorage, Alaska
    http://www.frostlineproductions.com
  • Adam Svatek
    July 31, 2012 at 12:57 am
    Thank you! Worked just as you said. -A
  • Jack Scalfani
    October 22, 2012 at 3:54 pm
    I have called Adobe and complained about this issue. I have the Alesis Multimix 4 and it keeps dropping audio. It won’t always let me toggle back using system default. This is a mess.
    Editing is a nightmare. Anytime I render it drops out. Have to reboot software and sometimes need to restart iMac.
    This is a huge issue and I blame Adobe Premiere for this issue. If it works sometimes then it should work all the time. It’s not a driver issue. Alesis has no drivers. Plug and play.
  • Philip Ohler
    November 17, 2012 at 12:18 am
    A little late to this post but wanted to get some feedback.
    Setting system sound settings to digital in/out seems to make the PP6 audio playback much better.
    Problem now is any audio played through other apps like QT and web browsers won’t play out.
    We are monitoring the audio out of the embedded SDI via a disembedder.
    Any suggestions for other settings would be appreciated.
    Thanks.
  • Matt Dean
    December 12, 2013 at 5:36 am
    I’m getting very similar issues, but i have to restart to restore the system audio.
  • Matt Dean
    December 12, 2013 at 5:40 am
    I’m sorry but this isn’t good enough.
    Are we expected to open System Prefs and change audio drivers every time we switch between applications because of this Premiere issue? That is not real world practical!
    I have been exploring moving over to Premiere from FCP7 but this is just all too hard. I should be able to use the same piece of hardware between multiple software packages, and have been seamlessly. Up until i tried to use Adobe Premiere.
    Somebody needs to fix this!
Page 3 of 3
