Activity Forums Apple Final Cut Pro Legacy audio filter??
  • Posted by Brian Pitt on May 15, 2006 at 9:16 pm
    I’m not much of an audio guy, but I’m hoping somebody out there is and might be able to point me in the right direction.
    I am editing a commercial and there is some audio that we shot in a large room, so there is a very small echo to it. Is there any filter in FCP or Soundtrack that will even slightly eliminate that?
    Thanks in advance.
    Brian Pitt replied 20 years, 4 months ago 2 Members · 2 Replies
  • Bouncing Account needs new email address
    May 16, 2006 at 12:07 am
    While background hum and certain continuous-type noises are relatively easy to isolate and reduce with special digital filtering…
    Reverb/Echo is one of the most IMPOSSIBLE-to-fix of audio problems, second only to severely CLIPPED (over-driven) levels.
    “EQ” won’t do it.
    Its reverb (repetition) of the PRIMARY audio… the same frequency that you want to KEEP.
    The “Noise Gate” is probably the best choice, but it will surely PUMP if its set high enough to have very much effect on the reverb. (So it could end up making many tracks sound worse.)
    Whatever you try will adversely affect the overall QUALITY of the audio being “fixed” and be very noticeable to the listener (especially compared to any “good” audio in the same production).
    I know that re-recording is not always possible,but once you have a poorly-recorded audio track, under many conditions, it just can’t be “fixed”.
  • Brian Pitt
    May 16, 2006 at 2:54 pm
    that’s pretty much what I thought…thanks for responding.
