Activity › Forums › Apple Final Cut Pro Legacy › Audio Filter for poor audio
Posted by Christopher Bagnall on April 7, 2006 at 4:09 pmCan anyone reccomend a filter for audio where the sound is tinny and echo(y)? I have footage of an interview in a kitchen and the room tone is not that great as the camera is about 8 feet away and the sound is very hollow. Thanks.
Gary Hughes replied 20 years, 5 months ago 3 Members · 2 Replies -
Bouncing Account needs new email address
April 7, 2006 at 9:26 pmI’m afraid if you shoot interview audio using the on-camera mic, these are the results you’ll get.
Good-qulaity audio simply must be recorded that way.
Echoey, hollow, “off-mic” audio is not correctable with any filter.You need to get the mic as close as possible to the subject’s mouth.
A Lav mic placed on the subject, or a “directional” mic aimed at the subject’s mouth and positioned by boom or stand JUST out-of-frame are the best methods.
If the room conditions are still too “bad” for recording a clean track, you must either MODIFY (deaden) the room, shut down the noise-makers in the room, or CHANGE rooms.
Gary Hughes
April 10, 2006 at 8:52 pmI completely agree with Matte. However, you may be able to improve it slightly (doubt it though with the on camera mic). There is a plugin from elemental audio that I have reduced reverb effect with. The recording was good to begin with, but the room was not. It was a highly reverberant room. This can be done with many compressors and expanders, but this one makes it easier to understand and tweak than others. https://www.elementalaudio.com/products/neodynium/index.html The idea is to compress all the audio above a certain volume and turn it up to a maximum loudness, then expand all the audio below that same level and turn it down as much as possible. With a really poor recording, don’t expect a miracle, but the plugin has a free trial, so give it a shot.
Gary
