Audio Drift Issue (47.962 khz & 29.96 fps???)
Hi everyone,
I captured some footage at DV50 through Final Cut Pro using Capture Now (because there were timecode breaks). I did two passes because the dailies tape has four channels of audio–I did one pass to capture channels 1 & 2 and one pass to capture channels 3 & 4, both with video.
In FCP, however, when I cut either or both clips into a sequence, the audio drifts very badly. I checked the original QT file (clip with channels 1 & 2) in my Capture Scratch and the audio drifts there, as well. So it’s definitely a capture problem. In the QT Inspector, it says the FPS is 29.96 and the audio is 47.962. Has anyone ever seen this before? This seems totally weird to me.
Here’s where it gets weirder: the clip where I captured channels 3 & 4 have an audio rate at 47.963, .001 higher than the other clip.
Any advice would be much appreciated!
Unfortunately, I don’t have the deck any longer, though acquiring it again probably won’t be a problem. I’m just trying to make sense of what’s going on!
