Activity Forums Apple Final Cut Pro Legacy Audio Drift Issue (47.962 khz & 29.96 fps???)
  • Richard Lowe
    November 4, 2009 at 7:08 pm
    Okay, well, I definitely didn’t set the deck (or change the configuration when I got it), so that may be it.
    As for the Firewire connections, I had the deck connected to my Powerbook’s Firewire 400 and a hard drive connected to my Firewire 800. Could that cause the problem? (I wasn’t sharing a hub or daisy-chain.)
  • Jeremy Garchow
    November 4, 2009 at 7:13 pm
    [Richard Lowe] “Could that cause the problem? (I wasn’t sharing a hub or daisy-chain.)
    It might. All macs have only one internal firewire bus, desptire how many firewire ports are on the machine.
  • Richard Lowe
    November 4, 2009 at 7:19 pm
    Do you suggest, then, installing a second firewire card on a Mac Pro? What would be a good solution for a laptop?
  • Jeremy Garchow
    November 4, 2009 at 7:24 pm
    [Richard Lowe] “Do you suggest, then, installing a second firewire card on a Mac Pro?”
    If using firewire for both capture and media storage, yes.
    [Richard Lowe] “What would be a good solution for a laptop?”
    You get a fw Express/34 card (intel) or a fw PCMCIA card (PPC) and separate the bus that way.
    Jeremy
Page 2 of 2
