Audio cleanup, bouncing to and from Audition
Aloha all,
I’ve got a rough cut of a short film ready. I did the cutting with the scratch track, and now I’ve gone back and synchronized all of the multitrack audio recordings from my Tascam DR-680. And I’ve discovered something… annoying.
If I double-click a video clip on the timeline, or an audio clip from the attached scratch track, it opens that entire original clip in the Source tab, with In and Out marked. But if I double-click an audio-only track, it opens just the portion of the original between the In and Out.
Likewise when I control-click and hit “Edit in Audition,” only the portion of the clip that’s highlighted on the Timeline opens.
Is there a way, a preference to change, that would convince the system to open the ENTIRE clip, with the In and Out intact? I want to do this for two reasons:
1. I record nat sound at the head and tail of each clip, so I can grab a noise print for cleanup
2. A lot of these clips get used more than once, and I’d prefer not to have to do repetitive work.
I know, I could open the source clips directly from my hard drive, and edit them there, then just relink. There’s a LOT of potential for error in that approach, though. I have thousands of files with very similar names, so the chances of me editing the wrong one, or relinking the wrong one, are pretty high.
The difference between theory and reality is that, in theory, there is no difference between theory and reality.
