Activity › Forums › Adobe Premiere Pro › aspect hd works fine in the source monitor but not the playback/sequence monitor
Posted by Accountclosed on June 13, 2007 at 2:21 ami’m having problems playing things in the playback/sequence monitor. when i hit play, the play forwards to the very end of the clip without playing a thing. so for example, with a 5 sec hdv clip, it skips to the very end in milliseconds.
however, in the source footage, it plays back fine. i’m confused. can anyone help?
footage was hdv captured on hv20 24p
captured using the cannon 24p settings in aspect hd.
aspect hd latest
premiere cs3
amd 2.6 processor
1 gig ram
4200 rpm drive
firewire sata 7200 rpm driveTim Kolb replied 19 years, 2 months ago 2 Members · 6 Replies -
Tim Kolb
June 13, 2007 at 1:24 pmThis can happen if there is a media/timeline frame rate mis match.
Isn’t the media from the Canon 23.976 fps? If the sequence is set for 24 fps…that slight difference makes some leftover time values that constitute less than a frame.
Check those issues. You can go into the ‘interpret footage’ dialogue and change the media frame rate to match if that is the case.
TimK,
Director,
Kolb Productions,Creative Cow Host,
Author/Trainer
http://www.focalpress.com
http://www.classondemand.net -
Accountclosed
June 13, 2007 at 3:30 pmHi Tim and thanks for the advice. i looked at the interpreted footage
https://a83.ac-images.myspacecdn.com/images01/60/l_68110e5e3b032738b130fed2bab643da.jpg
and thought it looked fine compared to the settings i used to capture.
https://a583.ac-images.myspacecdn.com/images01/7/l_19ff81fdb706ad5bc2c75e9a28fdeb56.jpg
is there another place to look to verify the footage frame rate to the sequence frame rate? thx
Tim Kolb
June 15, 2007 at 3:50 amInteresting…
Now that I’ve looked at the HV20 specs…it notes 1920×1080 as the framesize and the framerate as 24p.
I wonder if this video is a different format than the other Canon HDV cameras?
what is the format of the video clips? Is the framesize actually 1440×1080 or 1920×1080?
TimK,
Director,
Author/Trainer
Accountclosed
June 15, 2007 at 5:16 amthanks for responding Tim. when i check the footage specs thru the properties window in premiere its
1440 x 1080
23.976 fps
Uncompressed YUV 4:2:2however when i filmed i was in 1080i 24p mode. i also see the 1920 x 1080 as a spec but dont see that option in premiere. confusing. for capturing, i picked the aspect hd 1440 x 1080 24F mode within premiere , firewired.
so now i do see it working in the sequence window after closing premiere and re-opening. (i reregistered all the components for aspect) but now, after playing with any of the clips, shortening, lengthening, it does the same thing again. it skips to the very end when i hit play in the sequence window.
i’m confused as to what is going on. any thoughts tim?
Accountclosed
June 15, 2007 at 7:23 amoh ya, and one thing i forgot to add is i’m running vista ultimate. dont know if that would make a difference.
Tim Kolb
June 18, 2007 at 5:59 amVista could be an issue I suppose…I don’t run it so I don’t really know.
Typically this behavior pops up when there is something on the timeline that PPro is unsure how to address…fps differences that can result in “partial frame durations” or perhaps a corrupt file.
You might try removing a file, then play back, undo and remove a different file, etc until one file seems to solve the issue after it’s gone, but cause it when it’s on the timeline…
TimK,
Director,
Author/Trainer
