Activity › Forums › Apple Final Cut Pro Legacy › Apple Prores Codec (not 422) – Where is it?
  • Apple Prores Codec (not 422) – Where is it?
    Posted by Elijah Lynn on January 11, 2009 at 10:49 am
    I am trying to export a DV sequence to Apple ProRes but all I see is Apple PreRes 422.
    I thought there was a Apple ProRes for SD. Am I missing something?
    Rafael Amador replied 17 years, 8 months ago 3 Members · 4 Replies
  • Rafael Amador
    January 11, 2009 at 11:25 am
    Hi Elijah,
    Codecs are the same for SD or HD. Only the size changes.
    All the ProRess flavors are 4.2.2 and 10b.
    Cheers,
    Rafael
    http://www.nagavideo.com
  • Elijah Lynn
    January 11, 2009 at 11:35 am
    Thanks Rafael,
    For some reason (user error) when I exported my DV Sequence to ProRes the other day and it upsized it to HD. I just went to export it again and the resolution was a bit higher than DV, I cancelled and reset the timeline arrow and when I went to the settings dialog it was DV.
    Dunno what I was doing but I think I determined what was “causing” the problem. Me.
    Cheers Rafael!
  • Tom Wolsky
    January 11, 2009 at 2:23 pm
    Using ProRes has nothing to do with the format you exported. It’s a codec that works with SD or HD or anything else. You have to specify the frame size and frame rate when you export.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Rafael Amador
    January 11, 2009 at 2:59 pm
    Right.
    A rule to fallow when setting the size for a custom movie is to keep the pixels macro-blocks that the compressed codecs need.
    All the compressed codecs that I know use different macro-blocks sizes. MPG-2 use 16 x16, while DV use 6 x 4 pixels. H264 can use different macro-block sizes, being the smaller 4 x 4 pixels.
    That means that sizes like 400 x 225 should be avoided because some full lines can not be integrated in any macro-block. However I don’t know if this would have much effect in the picture.
    What I have no idea is the block structure used by ProRess. DVCPro HD I guess is DV like.
    Cheers,
    rafael
