Activity › Forums › Apple Final Cut Pro Legacy › Apple Prores 422 Codec dropping frames
Posted by Vintageseltzer on May 29, 2007 at 2:38 pmHello, I am unable to capture video without dropping frames and aborting . I have tried both the Aja Kona2: 720p 59.94 ProRes 422 and the Prores 422 HQ with no luck.
The material I am trying to capture is coming off of a DVCPROHD 720p 59.94 master from a Panasonic 1700 deck.
I am however able to digitize fine with the lower data rate Kona2 720p DVCPROHD codec, and even have no problems digitizing using the higher data rate Kona2 720p 59.94 10 Bit and 8 Bit codecs.
My system specs are as follows:
Power Mac G5 Dual 2.5 GHZ, 4 GB DDR SDRAM, AJA Kona2, Facilis Terrablocks Fiber Channel Storage, Final Cut Studio 2
I know using a DVCPROHD master will not gain much by using ProRes instead of its native DVCPROHD codec, I am just trying to test the ProRes workflow out for the future.
Am I missing something? Any suggestions?
Walter Biscardi replied 19 years, 3 months ago 14 Members · 25 Replies -
Gary Adcock
May 29, 2007 at 3:36 pm[VintageSeltzer] “Hello, I am unable to capture video without dropping frames and aborting . I have tried both the Aja Kona2: 720p 59.94 ProRes 422 and the Prores 422 HQ with no luck. Power Mac G5 Dual 2.5 GHZ, 4 GB DDR SDRAM, AJA Kona2, Facilis Terrablocks Fiber Channel Storage, Final Cut Studio Am I missing something? Any suggestions?”
read some of the other posts but it appears that the non-intel desktops are not suited to LIVE capture of material to the Apple prores codec in any HD format.
Have you tried capturing SD? it is not your storage, is it the CPU’s inability to compress in real time.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows -
Vintageseltzer
May 29, 2007 at 4:02 pmThanks Gary. I have not tried any SD capturing with the Apple ProRes yet, and probably wont even bother. The company I work for is planning on an intel mac upgrade in the next month, so I will conduct all my tests then. Thanks again for your input.
Chris Borjis
May 29, 2007 at 4:08 pm[gary adcock] “it appears that the non-intel desktops are not suited to LIVE capture of material to the Apple prores codec in any HD format.”
You have got to be kidding me.
That is totally unacceptable and I really hope apple is doing something to improve this situation.
That a less than 1 year old G5 Quad system can’t capture HD in the Pro res codec is a major “up yours” to apples customers.
Jeremy Garchow
May 29, 2007 at 4:58 pm[Borjis] “That a less than 1 year old G5 Quad system can’t capture HD in the Pro res codec is a major “up yours” to apples customers.”
Have you tried it on a Quad?
The ProRes codec is a major advancement, but it takes a lot of horsepower to compress/decompress. That’s why something like the ioHD (with the codec built in to compress/decompress) will help ‘older’ systems.
Jeremy
Chris Poisson
May 29, 2007 at 5:00 pmFYI my first attempts yesterday to capture to Prores failed miserably all the way around. Tried everything. This morning still no luck. I can capture 8 bit uncompressed 1080i, but no Prores anything. It really sucks. The machine (dual 2 gig with 4.5 gigs ram, SATA RAID 0) can’t keep up.
Walter Biscardi
May 29, 2007 at 6:27 pm[JeremyG] “The ProRes codec is a major advancement, but it takes a lot of horsepower to compress/decompress. That’s why something like the ioHD (with the codec built in to compress/decompress) will help ‘older’ systems.”
Absolutely true. The older systems, even one year old, simply won’t be able to keep up with the Pro Res codec in realtime if it’s a dual processor machine, at least from what I’ve seen. We have a Quad G5 here and hopefully that one will be able to do it in realtime.
But of course, you can easily capture DVCPro HD, create a ProRes timeline and then work like that. Then you render before output, but using the Pro Res codec.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Walter Biscardi
May 29, 2007 at 6:29 pm[Borjis] “You have got to be kidding me.
That is totally unacceptable and I really hope apple is doing something to improve this situation.”
Not really. ProRes is a major move forward with a codec and if you want to use that for capture (which is not necessary) then you will need a lot of horsepower to do so.
As gary suggests, you can also purchase an Io HD for an older machine or laptop if you wish to actually ingest using Pro Res.
As with all technology, if you want to absolutely keep up, you need to plan to update your computer ever 12 months. What I do here is we have three edit suites and I generally purchase a new computer every 8 – 10 months. The newest one goes in one suite and the others slide down. So my oldest machine is about 2 1/2 years old.
Bryan Keith
May 29, 2007 at 6:31 pmI dont have the upgrade yet, but from your experience so far, do you think a Dual 2.5 g5 with blackmagic HD pro is going to drop frames capturing as pro-res?
Chris Borjis
May 29, 2007 at 6:51 pm[walter biscardi] “Not really. ProRes is a major move forward with a codec and if you want to use that for capture (which is not necessary) then you will need a lot of horsepower to do so.”
And it goes back to reminding me of when Steve Jobs pimped G5 architecture as so much faster and better than pc stuff and now his foot is in his mouth.
oh well, what can one do? nothing really, just spend more money I guess.
Still though, a just over a year old Quad G5 PCI-E with 4gb of ram and 4GB Fibre channel disk array should have been able to handle this and I really hope it does.
Shane Ross
May 29, 2007 at 6:56 pm[Borjis] “Still though, a just over a year old Quad G5 PCI-E with 4gb of ram and 4GB Fibre channel disk array should have been able to handle this and I really hope it does.”
Transcoding to, yes. Capturing too…hope so. It is a very unique compression that takes a lot of horsepower.
[Borjis] “And it goes back to reminding me of when Steve Jobs pimped G5 architecture as so much faster and better than pc stuff and now his foot is in his mouth.”
Well when Avid introduced the DVxHD codec, the older Avid systems couldn’t handle it. You needed a newer more powerful one that could. This isn’t new. When a powerful complex feature comes along and takes a LOT of horsepower, many older models won’t be able to handle it. That is typical.
Shane
Littlefrog Post
http://www.lfhd.net
