Activity › Forums › Adobe After Effects Expressions › Animating wiggle effect problem
  • Animating wiggle effect problem
    Posted by Sami Bayley on September 23, 2021 at 11:13 am
    So, I’ve got a Null (Wiggle Null) controlling a whole scene. I’d like animate the wiggle so that it gradually gets more intense.
    I’ve currently got the wiggle set up with 2 sliders controlling frequency and amount. This is how it looks:
    wiggle(effect("Speed")("Slider"),effect("Amount")("Slider"))
    However, when I animate the keyframes, the time between keyframes is filled with a really jolty motion until it reaches the end keyframe!
    I thought maybe it was because the numbers on the slider were not whole numbers, so I used this on each slider:
    Math.round(effect("Speed")("Slider"))
    But to no avail!
    Can anyone help? What am I doing wrong?
    Sami
    Sami Bayley replied 4 years, 12 months ago 2 Members · 2 Replies
  • Dan Ebberts
    September 23, 2021 at 12:59 pm
  • Sami Bayley
    September 27, 2021 at 10:18 am
    Hey Dan, this is great. And defo working, I’ve just got a slight hiccup.
    This is what I’m working with:
    freq = thisComp.layer("WIGGLE").effect("Slider Control")("Slider");
    amp = 30;
    n = freq.numKeys;
    orig_xPos = transform.position[0];
    orig_yPos = transform.position[1];
    ground = effect("Ground")("Slider");
    if (n > 0 && freq.key(1).time < time){
    accum = freq.key(1).value*(freq.key(1).time - inPoint);
    for (i = 2; i <= n; i++){
    if (freq.key(i).time > time) break;
    k1 = freq.key(i-1);
    k2 = freq.key(i);
    accum += (k1.value + k2.value)*(k2.time - k1.time)/2;
    accum += (freq.value + freq.key(i-1).value)*(time - freq.key(i-1).time)/2;
    if (orig_yPos < ground) {
    [orig_xPos, orig_yPos];
    } else if (orig_yPos > ground) {
    [orig_xPos, ground];
    }else{
    accum = freq.value*(time - inPoint);
    wiggle(1,amp,1,.5,accum)
    I can’t get things to work with the ground plane I’ve added. It throws the rest of the keyframes off.
    The “ground” slider is for a shadow rig that I put together that basically stops the main layer clipping with the shadow.
    Any idea’s? Again, I’m pretty crap at this so any help is seriously appreciated.
