Activity › Forums › Adobe After Effects Expressions › animating position at fixed intervals with fixed values
Posted by Jonathan Reyes on December 1, 2009 at 2:44 pmHello,
I was wondering if there was an expression that can move a layer 5 points up in the y axis, pause for 2 seconds, then move up 5 points up again, pause for 2 seconds, move 5 points up, etc. I also want this to animate moving 5 points up rather than having an instant jump. any thoughts if this is possible? thanks!Dan Ebbertsreplied 13 years, 4 months ago 4 Members · 11 Replies
Xinlai Ni
December 1, 2009 at 4:44 pmTry this:
timeToClimb = 1;
timeToStay = 2;
initialY = 243;
positionY = initialY - 5 * Math.floor(time / (timeToClimb + timeToStay));
t = time % (timeToClimb + timeToStay);
[432, linear(t, 0, timeToClimb, positionY, positionY - 5)]Xinlai Ni
Software Engineer, Google Inc. -
Dan Ebberts
December 1, 2009 at 4:50 pmIt will be something like this:
moveTime = .3;
holdTime = 4.7;
delta = [0,-5];seg = Math.floor(time/(moveTime+holdTime));
t = time % (moveTime+holdTime);
value + delta*seg + linear(t,holdTime,holdTime+moveTime,0,delta)Dan
Jonathan Reyes
December 2, 2009 at 3:12 pmThank you both! Works like a charm! If you have some time, could you explain what’s happening here? I know some basic expressions, but am by no means an expert (or even a novice for that matter) and I like to know how things work before i implement them in my projects. Also, using this method, is it possible to “ease” the animation of the position? thank you!!
Dan Ebberts
December 2, 2009 at 8:41 pmWherever you see “linear”, just change it to “ease”.
I wish I had time to explain how it works, but I’m pretty jammed up this week.
Dan
Jonathan Reyes
December 2, 2010 at 8:56 pmThanks again for this wonderful expression. However, I was wondering how I can apply to this to time. For example, I have a clip that I want to Time Remap where it plays for 1 second, pauses for 5 seconds, resumes play for 1 second, pauses for another 5 seconds, etc. It seems like this expression would work with some tweaks, unfortunately I’m not the best at this and can’t figure it out. any help would be appreciated, thanks!
Dan Ebberts
December 2, 2010 at 9:08 pmTry this:
moveTime = 1;
holdTime = 5;seg = Math.floor(time/(moveTime+holdTime));
t = Math.min(time % (moveTime+holdTime),moveTime);
seg*moveTime + tDan
Sebastian Heinrich
May 29, 2013 at 6:19 pmHi,
I am quite a noob when it comes to expressions.
Basically what I am trying to achieve is to connect your Expression (what perfectly does what I need) with an inertial Bounce.
I want a layer to move in fixed intervals but also have a bounce at the end position. And I don’t want to use keyframes.
I have been using the inertial Bounce Expression from Graymachine which is based on keyframes.
But I am to stupid to find a way to connect these Expressions.
Do you know how to do this?Thank you!
So I want to connect this:timeToClimb = 1;
timeToStay = 2;
initialY = 243;
[432, linear(t, 0, timeToClimb, positionY, positionY - 5)]with this:
amp = .05;
freq = 1.0;
decay = 4.0;n = 0;
if (numKeys > 0){
n = nearestKey(time).index;
if (key(n).time > time){
n--;
}}if (n == 0){ t = 0;
}else{
t = time - key(n).time;
}if (n > 0){
v = velocityAtTime(key(n).time - thisComp.frameDuration/10);
value + v*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
}else{value}
Dan Ebberts
May 29, 2013 at 9:10 pmI think this gives you the appropriate overshoot, but I don’t think you’re going to see much bounce with a velocity of 5 px/sec:
timeToClimb = 1;
timeToStay = 2;
step = 5;
initialY =243;
positionY = initialY - step * Math.floor(time / (timeToClimb + timeToStay));
t = time % (timeToClimb + timeToStay);freq = 1;
decay = 2;if (t < timeToClimb){
[432,linear( t, 0, timeToClimb, positionY, positionY - step)];
}else{
amp = step/timeToClimb;
w = freq*Math.PI*2;
[432,positionY - step] - [0,amp*(Math.sin((t-timeToClimb)*w)/Math.exp(decay*(t-timeToClimb))/w)];
Dan
Sebastian Heinrich
May 29, 2013 at 9:38 pmHi Dan,
wow, that works perfectly.Yes, sure, those example values 5px/sec wouldn’t do it.
I am creating a slideshow with hundreds polaroid images. This is so awesome coz it’s completely autmated now.
I wish I was able to come up with such solutions. Would probably take me days. I can only partly understand the code. That’s really bugging me.
Thank you so much.
Sebastian
