Activity › Forums › Adobe Premiere Pro › Animating a Still Image
Posted by Justin Toney on February 17, 2015 at 5:12 pmI’m hoping someone can tell me the technical name for this. Lets say I have a still image and I want to animate a zoom and rotate so that it doesn’t just look plain. What is this called?
Shane Ross replied 11 years, 7 months ago 4 Members · 5 Replies -
Shane Ross
February 17, 2015 at 5:40 pmMotion Control. Some people say “the Ken Burns Effect,” as if the guy invented the process (he did not). Or “moves on stills.”
Drop the picture onto the timeline. Double-click to open it in the Viewer, click on the EFFECT CONTROLS tab. Click on the triangle to the left of MOTION and position the indicator to where you want the move to start…click on the stop-watch icon to the left of SCALE and POSITION…that adds a keyframe…now position the indicator to the place you want the move to end, and then adjust the SCALE and POSITION to where you want it…a keyframe will automatically be added. And then when you play, the move you created will happen.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Justin Toney
February 17, 2015 at 6:03 pmThat isn’t what I was referring to. What I specifically want is to have a foreground object appear to have depth while the background, of the same image, moves accordingly. Pan and Zoom is a different concept altogether.
Tero Ahlfors
February 17, 2015 at 6:27 pmhttps://www.youtube.com/watch?v=ZVrYyX3bHI8
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Joseph W. bourke
February 17, 2015 at 6:57 pmIt’s often called The Kid Stays in the Picture photo effect. Do a search on it, and you’ll see why.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com -
Shane Ross
February 17, 2015 at 7:59 pmYes…this requires using photoshop and After Effects. Photoshop to create the different layers, and After Effects to animate them.
That video should explain it.
Shane
Little Frog Post
