Activity › Forums › Adobe After Effects Expressions › animate scale from “0” tot “x”(slider control amount) with easy ease
  • animate scale from “0” tot “x”(slider control amount) with easy ease
    Posted by Bas V breugel on July 4, 2018 at 9:11 am
    Hi guys,
    Im trying to making a bar graph animate from 0 to an amount referrenced from another layer.
    So I have a text layer called “Shot_Percentage” wich has the amount “33.3”
    Then I want to scale a shapelayer from “0” to “33,3” and make it ease out at the end.
    Scott Mcgee replied 8 years, 2 months ago 2 Members · 3 Replies
  • Scott Mcgee
    July 4, 2018 at 9:48 am
    As long as your shape to start is 100% and 100% of the bar graph. Then you just need to copy and paste this into your scale of the transform properties.
    Then yb = pickwhip your slider control.
    transition = 1
    ya = 0;
    yb = effect(“Slider Control”)(“Slider”);
    x = 100;
    if(time < (inPoint+outPoint)/2){
    ease(time,inPoint,inPoint+transition,[x,ya],[x,yb]);
    }else{
    ease(time,outPoint -transition,outPoint,[x,yb],[x,ya]);
  • Bas V breugel
    July 4, 2018 at 12:16 pm
    Thanks! I adjusted your expression slightly because i forgot to mention I’ve made a horizontal bar graph. And now the amount it grows to is not from a slider but straight from complayer.
    transition = 1
    xa = 0;
    xb = parseInt(thisComp.layer("Shot_Percentage").text.sourceText);
    y = 100;
    if(time &lt; (inPoint+outPoint)/1){
    ease(time,inPoint,inPoint+transition,[xa,y],[xb,y]);
    }else{
    ease(time,outPoint -transition,outPoint,[xb,y],[xa,y]);
  • Scott Mcgee
    July 5, 2018 at 8:19 am
    Sorry I missed the bit about you using sourceText.
    If it’s for someone else to use that isn’t after effects savvy. I sometimes put in an alert feature that tells them it isn’t a number.
    for sourceText layer
    a = thisLayer.text.sourceText
    if(isNaN(a)){
    “THIS IS NOT A NUMBER”
    }else{
    text.sourceText;
    also if the text layer is to be hidden. I also add this to it to the opacity.
    if(isNaN(a)){
    100
    }else{
    0
    It’s nothing flashy, but for someone who doesn’t know how to use it and wonder why it isn’t working, does come in handy.
