Activity Forums Adobe After Effects Anaglyph 3D Effect with only 1 Adjustment Layer?
  • Anaglyph 3D Effect with only 1 Adjustment Layer?
    Posted by Royce Jacobs on January 22, 2022 at 12:52 pm
    Hey guys, I was pondering my orb wondering if there was a way to create a single preset for one adjustment layer to create an anaglyph 3D (red/blue glasses) effect. I know I could create 2 presets to each change the color channels with one having a transform offset, but this was more a mere curiosity for the sake of knowing the program better.
    Any ideas?
    Royce Jacobs replied 4 years, 6 months ago 3 Members · 6 Replies
  • Michael Szalapski
    January 24, 2022 at 4:03 pm
    Are you just asking for chromatic aberration kind of effect or genuine 3d glasses?
    AE has a built-in 3d Glasses effect, but it’s dependent on you having two sources to drive it (either footage from two cameras or two precomps with offset cameras).
  • Royce Jacobs
    January 25, 2022 at 1:09 pm
    Hey there, just looking for an effect, not actual 3d. So one source with basically 2 position-shifted, color-tinted versions. I was thinking maybe something with echo, but then didn’t know how you could color different echos differently. idk, it was more of a mental puzzle exercise than anything, there may not be a way
  • Filip Vandueren
    January 28, 2022 at 9:04 am
    This seems to work:
  • Royce Jacobs
    February 22, 2022 at 12:32 pm
    Interesting.. I don’t get the same result (cc 2022)
    There’s no fx on the images right?
  • Filip Vandueren
    February 22, 2022 at 12:57 pm
    I think this is because you have an alpha channel and I had a black solid BG.
  • Royce Jacobs
    February 22, 2022 at 3:19 pm
    Ah, quite right! Adding the solid bg did the trick, good looking out ;D
    I don’t understand quite why this works but you solved the puzzle! But now I’m curious why are we able to see the original position and not only the offset position?
