AME export from PPro differs from preview on timeline?
Hi all,
Trying to export some SD sized h264 QTs for client approval (of my 1920×800 timeline) and I’m getting some very odd results….
Sequence in question has 720×576 DVPAL QT source footage scaled up and pan/scanned in my HD Cinemascope timeline.
When previewed (using GPU acceleration – all yellow lines) it looks as expected.
When SD letterboxed output is viewed from within AME it looks as expected.However the resulting 720×404 h264 looks TOTALLY different! Clip is scaled up 2x more than it should and in some cases the video is just displayed by torn black & white noise.
I’ve tried exporting with and without ‘use previews’ and checking maximum render quality on and off…to no joy.
Currently I have to export a full-size uncompressed QT and then scale it down via Quicktime Pro Player to an SD h264. Not and ideal workflow when I have 70+ sequences to o/p.
Any thoughts guys?
Jim.——————————-
Production Premium CS5.5 – Mocha v1.5
MacPro 3,1 8-core 3.2GHz / 32GB RAM / NVidia Quadro 4000 / OSX 10.6.8
Decklink Extreme+ 3D / 3TB RAID-0 local / 6TB XServe + United Digital RAID on 10GbE
