Activity Forums Avid Media Composer AMA to protools
  • AMA to protools
    Posted by Mike Jeffs on March 21, 2012 at 1:07 pm
    Looking for best/ quickest workflow on how to export a aaf or omf to got to a protools 9 daw for mixing from a exclusively AMA linked project. The protools system is connected to the same nas server as the avid machine. Not sure which settings to use
    Mike Jeffs
    Video Coordinator
    BYU-Idaho
    Andrew Mckee replied 14 years, 6 months ago 4 Members · 5 Replies
  • Richard Sanchez
    March 21, 2012 at 2:15 pm
    Simply put. You can’t. You need to transcode your media to MXF to send it to pro tools. This have changed with 6.0, but with 5.5 and prior this was the case.
    Richard Sanchez
    Los Angeles, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Peter Groom
    March 21, 2012 at 3:18 pm
    OMF, consolidate and Embeded.
    Should make a single file .omf and check the size. a few k and it has no audio. Megs + and it does contain the audio.
    Peter
    Post Production Dubbing Mixer
  • Richard Sanchez
    March 21, 2012 at 4:49 pm
    I meant to say, this may have change with 6.0 but I don’t know.
    Richard Sanchez
    Los Angeles, CA
  • Mike Jeffs
    March 21, 2012 at 10:47 pm
    So sorry I should have said I was running MC 6. I was getting a weird error at first when i was trying to create a Embedded AAF, but now that i have installed the update I can export a AAF by consolidated the media and then selecting embedded into AAF. still not sure if this is the best way but it works for me.
    Thanks for the input guys
    Mike Jeffs
    Video Coordinator
    BYU-Idaho
  • Andrew Mckee
    March 22, 2012 at 3:59 pm
    Yeah it works just transocoding on export to AAF. I would choose the option which places all your footage in a folder next to the AAF rather then embed it in the file itself. I have never had a problem this way, but have run into several with embedded ones. And OMFs are fine if your seuqences are short but have a file size limit.
    Andrew McKee
    Editor/Colourist
    Avid Certified Instructor – MC5.5
    Apple Certified Trainer – FCPX
    Pixelwizard.net
