Activity › Forums › Apple Final Cut Pro Legacy › Am I missing something
  • Am I missing something
    Posted by Lee115 on August 26, 2005 at 1:11 am
    This is most likely a stupid question but I’ve been searching through posts for a while now and thought I might just ask.
    What would I gain by buying a capture card like a decklink one?
    Most of my work is print and motion graphics that is output to DVD but,
    I do a little bit of video work and have a SD digital camera, I capture through the firewire.
    So what would a card like this do for me that I can’t do now?
    Is the quality any different?
    Josh
    Lee115 replied 21 years, 1 month ago 3 Members · 5 Replies
  • Shane Ross
    August 26, 2005 at 2:30 am
    The only thing you gain by getting a decklink is the ability to capture SDI or Component or Composite in the 8-bit and 10-bit formats.
    Working with DV only via firewire…outputting to DVD? You don’t need it.
  • Lee115
    August 26, 2005 at 2:33 am
    Thanks Shane,
    Josh
  • Dan Riley
    August 26, 2005 at 3:48 am
    Here’s the thing….
    If you edit in FCP using a DV sequence, you are goint to have
    titles and graphics that don’t look very good. The compression
    of the luminance is 5 to 1. This causes fuzzy titles.
    The chroma information is 1/2 of what you get with an
    uncompressed 10 bit SD sequence. This causes scmeary chroma.
    Your DV footage will look the same in both situations,
    but any titles you create and any graphics you import,
    they will not look as good when editing on and output from a
    DV sequence.
    So, do you need an Aurora or Blackmagic or AJA card
    to edit 10 bit uncompressed sequences…no.
    You just tell FCP to use the uncompressed codecs when
    importing and you make your sequence an uncompressed
    sequence. But to view that sequence on your external monitor
    you do need one of the above cards.
    Do you need a card to be able to output an uncompressed
    sequence to at DVD, via compressor for instance…no.
    My testing shows the quality of titles and graphics
    will be much higher when outputing an uncompressed
    sequence to DVD than from a DV sequence.
    Dan
  • Dan Riley
    August 26, 2005 at 4:06 am
    Something I forgot to mention about editing with an
    uncompressed 10 bit sequence…
    If you plan on outputting to DVD, you will not need
    faster drives. Since you aren’t outputing in real time
    to a DigiBeta (or whatever) tape deck, you won’t have to
    access the data so fast that it causes you to drop frames
    or not playback at all. You can simply render the sequence
    and export to DVD via compressor.
    However, if you DO want to play out an uncompressed
    sequence to tape, even if it’s to your DV machines,
    you will need a disk array, either SATA or Fiber.
    Some will say firewire 800 is ok but this is not reliable.
    A four or eight drive array is really the key to multiple
    streams of RT video and no dropped frames with
    uncompressed 10 bit SD video. I’m sure you will hear
    other opinions…but this is my experience.
    Dan
  • Lee115
    August 26, 2005 at 4:27 am
    I see, thanks for the info.
    Like I said, most of my stuff is output to DVD and what isnt is rendered as a quicktime mov
    I don’t see i will ever need to output back to tape for what I do.
    Thanks, Josh
