Activity Forums Adobe After Effects After Effects Star Mask Not Looking Right
  • After Effects Star Mask Not Looking Right
    Posted by Kevin Olmsted on July 21, 2017 at 7:58 pm
    Hello all,
    I am working in a project that requires a lot of star masks… some for Element 3D Custom Masks and some for other graphic elements. While working in the project, as happens on a frustrating number of occasions, I accidentally created a star shape rather than a mask. I quickly deleted it and highlighted my layer and made the mask. It does not look right.
    I know how to fix this if this were a shape layer… I would simply adjust the inner radius. How do I fix this or change this when making a mask shape on a layer? (I think) I know all of the various adjustments one can make while making a mask shape – holding command, holding shift, rolling the mouse wheel, arrow left/right – to change it’s appearance or parameters, but I can’t figure out how I did this and how to go back to the “stock” mask shape.
    Hopefully the picture attached properly.
    Any help is greatly appreciated.
    Jeff Hinkle replied 9 years, 2 months ago 2 Members · 1 Reply
  • Jeff Hinkle
    July 21, 2017 at 9:22 pm
    Had this happen to me a couple times. Draw a star with the tool, nice and big. Then hold Cmd/Ctl and drag back towards the center, but not all the way. You’ll see your inner radius start to “fatten up.” Release Cmd/Ctl and drag outward again to check if the shape is the way you want it. If not, do the Cmd/Ctl-drag-in-out thing again until it looks how you want it. Should clear it up.
    It is easier to destroy than to create.
    More fun, too.
