Activity Forums Adobe Premiere Pro adobe dynamic link. for every shot an AE comp file to import than in premiere pro. not easier??
  • adobe dynamic link. for every shot an AE comp file to import than in premiere pro. not easier??
    Posted by Bart Straman on May 13, 2007 at 8:00 am
    heey Guys
    i have a question.
    i use the Dynamic link option in Premiere pro to import AE comp files into Premiere pro.
    i have like 80 shots. they go first into AE for a special moonlight filter (cinema styl) and some other effects, per shot customized different. and then into premiere pro.
    no iv’e noticed that i have to make a new comp file for every shot, because if i put 10 shots into 1 comp file in AE(under eachother) and then use dynamic link into Premier pro, than i see only the first shot on the list. if i import the comp file from AE (using dynamic link)
    can this be done easier?? because after 4hours of shots, i have like 10 scenes, with 80 shots. so 80 comps that update/been checked every 15min by Premiere is not fun
    thanxs
    Bart.
    ps: and because simple “copy past” doesn’t work with any animation presets or any other effects applyed to the footage in AE i have to use the dynamic link.
    Bart Straman replied 19 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
