Activity › Forums › Adobe After Effects › Adobe after effects CS3 plugins into CS5
Posted by Santosh Khad on May 7, 2010 at 8:40 amHi !!
I just want to know if the adobe after effects cs3 plug ins will work in adobe after effects CS5Kim Segel replied 16 years, 3 months ago 3 Members · 2 Replies -
Todd Kopriva
May 8, 2010 at 3:37 pmI just wanted to back Dave up on this important point.
from After Effects Help:
“Important: Because After Effects CS5 is a 64-bit application, only 64-bit plug-ins can run in After Effects CS5. Plug-ins created for previous, 32-bit versions of After Effects will not run in After Effects CS5. To inquire about availability of 64-bit versions of plug-ins, contact the plug-in vendor or provider.”There’s more information toward the bottom of that page about where to find information about 64-bit plug-ins.
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment. -
Kim Segel
May 10, 2010 at 5:35 am…there are however 2 bits of good news on this:
1. Adobe is including a free old 32 bit version with your CS5 purchase. So if you absolutely have to use a plug-in, you could use that.
2. Scripts (at least the ones I’ve tried so far) seem to work fine in 64 bit CS5 AE.
Kim
A computer once beat me at chess, but it was no match for me at kick boxing.
–Emo Philips
