Activity › Forums › Adobe Premiere Pro › Adjust levels to Loudness Radar
Posted by Joseph Freeman iii on January 23, 2019 at 3:10 pmI have a number of overlapping clips (8) for a fight sequence, which individually are adjusted not to exceed the -24 threshold (all legal) in the loudness radar. But when the sequence is played, the flight section exceeds the -24 threshold as per the yellow indicators.
Any suggestions on how to bring the clips down (and keep the same levels relationship) to the -24 threshold, without destroying the relationship of the various clips?
Thank you.
John Heiser replied 7 years, 7 months ago 5 Members · 8 Replies -
Tero Ahlfors
January 23, 2019 at 7:37 pmWell you’d need to mix the different audioclips so that they stay within the desired loudness level.
Joseph Freeman iii
January 23, 2019 at 7:50 pmThanks Dave for the swift reply.
Adjusting the master Levels also affects the other audio tracks.
My solution was to create a nested sequence which holds all the fight audio clips and the Volume Level for the Nest is lowered. -
Joseph Freeman iii
January 23, 2019 at 9:38 pmHi Tero,
Adjusting the volume level for the nest the volume level relationship between the clips was maintained and Loudness Radar verified the adjustment to the -24 threshold.
Thanks for your response. -
John Pale
January 24, 2019 at 4:23 amWhy nest it that way? Just route them to a submix channel (then you can keyframe it as a group)
Joseph Freeman iii
January 24, 2019 at 7:39 pmI will have to investigate submixing….Thanks for the tip.
Herb Sevush
January 27, 2019 at 3:11 pmYou can select a group of audio clips and raise or lower the volume in increments of 1db by using the keyboard shortcuts / left bracket key decreases / right bracket key increases. If you hold the shift key down the increments will be 6db. If you need more granular control, nesting or creating a sub group in the track mixer will work fine.
Herb Sevush
Zebra Productions
nothin\’ attached to nothin\’
\”Deciding the spine is the process of editing\” F. Bieberkopf -
Joseph Freeman iii
January 27, 2019 at 9:06 pmThanks Herb for the keyboard shortcut tip, I hadn’t thought of that.
My solution was to nest and adjust the nest. -
John Heiser
February 1, 2019 at 4:35 pmThis is the same net effect of a submix track, except that if your all your tracks combined to levels exceeding -0dB, you’d get some nasty artifacts. Pulling back the master fader of your nest fixes that, of course.
One advantage to using the nest method is your Audio Track Mixer has fewer faders – just one for the nested sequence vs. keeping all the faders for your SFX tracks plus adding one for the submix. The disadvantage of the nest is that you have to step in and out of the nest to adjust individual clip or track levels, whereas the submix method keeps everything out where you can easily get to it.
John Heiser
Senior Editor
o2 ideas
Birmingham
