Activity › Forums › Adobe After Effects › Adding a solid background to a rendered animation
  • Adding a solid background to a rendered animation
    Posted by Victor Soares on November 16, 2011 at 6:45 am
    Hi All,
    I am Victor Soares from South Africa. I have recently started playing with After Effects CS5.5 having never used footage editing software before.
    What I am trying to do is small animation clips for various projects. What I do is do the animation using 3ds max and then I wanted to use after effects to do small manipulations.
    One of the things I am trying to get my head around (and this is probably really basic) is the following:
    – I render my animation as a series of images in 3dsmax and export as png files
    – This saves me a lot of hard drive space as the PNG files are small, but the images do not have a background (only the subject matter is rendered)
    – I then stack them in AE and can render them to a .mov clip, however the missing background now just plays as a solid black background
    – Is it possible to have the background rendered as invisible?
    – If not, is possible to add a solid color background the the .mov clip?
    Victor
    Stefan Hinze replied 14 years, 10 months ago 3 Members · 2 Replies
  • John Cuevas
    November 16, 2011 at 4:37 pm
    Yes. If you are rendering to quicktime.mov – animation codec for instance, in your lossless settings you would change your video output for channels to “RGB + Alpha” When it plays back in your quicktime player, it will still have a black background but if you import into a NLE(or back into AE) it will have an alpha channel that maintains your transparency, now you can now place it over video.
    “Shift + Y” will will open up the solid settings, pick a color and put it on the bottom of you comp stack.
    Johnny Cuevas, Editor
  • Stefan Hinze
    November 19, 2011 at 5:35 pm
    hey there,
    check if there is an option in the 3D program to give the PNG´s a ALPHA-Channel.
    if the have, youre fine and it should be no problem 😉
    if the PNG´s are without ALPHA-Channel, use a KEY-Effect.
    play i little with them and you get there!
    hope this helps
    greetings
    (take a step back, to see the bigger picture)
