John Rofrano
March 21, 2010 at 7:38 pmI’ve not tried running the 32 bit Vegas on the 64 bit machine as I am just trying to get my current project finished!
It doesn’t cost anything to install and it works perfectly fine with Vegas Pro 64-bit projects. It’s always a good idea to not change anything in the middle of a project, but if it solves a particular problem for you, just be sure to take a backup or restore point before changing anything on your PC. I use Vegas Pro 32-bit and 64-bit interchangeably all the time on my Windows 7 64-bit workstation without problems.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Marcelo Banzaii
September 11, 2010 at 9:22 pmHi Noah Beney.
Sorry about my english… do you speak portuguese?I´m with the same or like the same problem.
I´m shooting with a panasonic handycam that shoot in full HD with avchd codec, but i´m edting in adobe premiere CS4.
The problem is when I export the video in H.264 format. At any given time the image jumps, it is not happen all time, it is at just determined time.
After several attempts to export with different settings, I managed to solve the problem exporting to WMV in full hd.
This was the only way I could make it work and and I still do not know how to export in h.264 without the image jump.
