Activity › Forums › Apple Final Cut Pro Legacy › a way to find multi-clips on a timeline?
Posted by Blase Theodore on October 11, 2012 at 5:56 pmDoes anyone know of a way to find multi-clips on a timeline? (Other than just clicking on them individually?)
Blase Theodore replied 13 years, 11 months ago 3 Members · 3 Replies -
Shane Ross
October 11, 2012 at 8:37 pm -
Jerry Hofmann
October 12, 2012 at 9:06 pmWell, if the name contains the word Multiclip, you could select the sequence open in the timeline, and find the multiclips that way.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Blase Theodore
October 12, 2012 at 9:20 pmOk thanks anyway guys.
(You can’t do a find for them, I tried. FCP appends “_sync” to the filename, but it doesn’t see it in search results.)
The problem is that multi-clip timecode gets screwy when exporting XML’s from FCP, which is problematic when you’re trying to online a job from FCP to something like Davinci.
Additionally, the “collapse” multiclip function is basically worthless, because there’s no way to do it permanantly. (The ability to uncollapse at any time means FCP is really just hiding it from you.)
Which means I have to find those clips by hand, and matchframe their replacement by hand.
Bummer.
