Activity Forums Adobe Premiere Pro 1080/50p reccomendation
  • 1080/50p reccomendation
    Posted by George Kalogeris on March 6, 2013 at 5:49 am
    recommended settings for exporting to file from CS6 (archiving purposes)?
    I have 1080/50p footage from Sony NEX-EA50
    and I ‘d like to do some renderless cut-joins.
    Also what could be the best settings for PAL DVD out from my footage (25p or 50i ?) (delivery purposes)
    George Kalogeris replied 13 years, 5 months ago 2 Members · 4 Replies
  • Bernhard G.
    March 6, 2013 at 7:56 am
    Hello,
    for renderless cut-joins You would need a to utilize a feature called
    smart rendering.
    CS6 supports smart rendering for DV, DVCPro, XDCam formats,
    but not for AVCHD which You have. (Perhaps in CS7 ?)
    see:
    https://blogs.adobe.com/kevinmonahan/2012/10/11/smart-rendering-in-premiere-pro-cs6-6-0-1-and-later/
    Since 576p/25 isn’t standardized for DVD, the obvious solution is to convert
    1080p/50 to 576i/25 thus maintaining temporal resolution.
    Best regards,
    Bernhard
  • George Kalogeris
    March 6, 2013 at 1:15 pm
    if 576/25p isn’t standard for DVD
    what’s the hype about “progressive playback” in all modern DVD players ?
  • Bernhard G.
    March 6, 2013 at 5:41 pm
    Video on a DVD is always interlaced, even if the source was progressive.
    Those DVD players are able to read a flag in the datastream
    that tells them, that the two stored fields belong to a single frame.
    Problems:
    – only few authoring apps could set the flag
    – DVD players need to be connected via RGB or HDMI
    that reading the flag makes sense at all by passing the
    progressive image to the TV.
  • George Kalogeris
    March 6, 2013 at 7:46 pm
    Thanks for clarifying how strict DVD standard is.
    Back to my main question. What kind of exporting is your proposal for retaining most of the detail 1080/50p 4:2:0 has to offer while not spending too much space.
