Activity Forums DaVinci Resolve zoom via whole timeline – track options
  • zoom via whole timeline – track options
    Posted by Andi Winter on February 19, 2011 at 2:46 pm
    hi all…
    i am wondering where the PTZR changes are stored. normally if i would like to change something for the whole timeline i can do that via the track window view. but the ptzr arent stored in a node…
    but there must be an easy way of doing for example slight V size or Hsize changes for the entire timeline i guess.
    any hint?
    Illya Laney replied 15 years, 6 months ago 4 Members · 3 Replies
  • Dan Moran
    February 19, 2011 at 6:26 pm
    You could try making a group?
    Select all the shots on the timeline.
    Right Click and select add into new group
    A red outline should appear on the timeline thumbnails
    Make your PTZR change
    Select all the clips again and select remove from group.
    Should only take a couple of seconds to do!
    Hope this helps
    Dan Moran
    Application Specialist
    Blackmagic Design EMEA
  • Charlie Edison
    February 20, 2011 at 12:04 am
    The most efficient way to make a change to all clips is to use a “ripple value”
    To change only a few clips in your time line use the clip numbers to define which clips to ripple,
    eg. Make the change you want on clip 6, then type \\\”7,14\\\” hit ripple and clips 7-14 will get the change you made to clip 6
    The are 4 ripple value modes so read up the manual to master this function. It\\\’s very useful.
  • Illya Laney
    February 21, 2011 at 7:00 am
    Could what you’re talking about be accomplished this way?
    1. Go to the Format tab.
    2. Click on the track tab on the lower right timeline to activate the track mode.
    3. Go to the Output Transform settings in the Output tab and adjust whatever you want. The transform will affect all the clips in the current timeline and you can save it as a preset.
    twitter.com/illyalaney
