Activity › Forums › Apple Final Cut Pro Legacy › Zoom Q3 Handy Camera Import Question
  • Zoom Q3 Handy Camera Import Question
    Posted by Ty Ford on October 26, 2010 at 8:49 pm
    Working with a Zoom Q3 SD.
    On the desktop, the 29.92, 4:3 files dragged from the camera files are .mov and QT shows it is using the Apple MPEG-4 decompressor. When I import them in to FCP with DV NTSC 48 and drop them on the timeline, I don’t get the usual pop-up about changing the timeline settings of the timeline to match the sequence. The clips need rendering and they show up in the browser as 10 fps rather than 29.97.
    Is there a preferred workflow for a toy cam like this or does everything need to be rendered?
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Watch Ty play guitar
    Ty Ford replied 15 years, 11 months ago 2 Members · 2 Replies
  • Andy George
    October 26, 2010 at 10:19 pm
    You’ll want to convert your footage to a more edit friendly format first. Proress 422 would preserve the quality. You could probably get away with just doing it to DV50. I try to stay away from straight DV in any situation. If you add graphics to your edit they will be unnecessarily compressed.
    Mpeg streamclip is a free program that will do it or apple compressor.
    Your final timeline should be 640×480 @ 30FPS, I suspect the timeline will set itself to that once you have converted the footage and re-dropped it.
    -Andy George
    Senior Editor
    http://www.chiselindustries.com
  • Ty Ford
    October 27, 2010 at 2:13 am
    Thanks Andy,
    will do.
    Ty
