Activity Forums VEGAS Pro Zoom in Picture In Picture using Pan Crop?
  • Zoom in Picture In Picture using Pan Crop?
    Posted by Brad Leigh on November 9, 2011 at 12:02 am
    Hello and thanks again for your help.
    I am doing a technical educational video. I use picture in Picture to show a machine reacting to the operators controls. I shot with two cameras. I approximated my PIP when framing, meaning the closeup was shot using using the upper left quarter of the frame. I would use the upper left quarter of that frame with pan crop to create the PIP. It works very well. But I’ve decided I would like to zoom in a bit. I see how to do this in pan crop if I am using a full frame. But I don’t see how to do this using the upper left quarter frame. I checked the manual and the only reference I see for using pan crop to zoom is if I am outputting that track to full frame. Is this possible?
    Thank You, you guys are life savers.
    Brad
    i7 2600 3.4 Ghz 8Gig Ram , Win 7 Pro, Vegas Pro 10
    John Rofrano replied 14 years, 10 months ago 2 Members · 3 Replies
  • John Rofrano
    November 9, 2011 at 12:33 am
    [Brad Leigh] “I’ve decided I would like to zoom in a bit. I see how to do this in pan crop if I am using a full frame. But I don’t see how to do this using the upper left quarter frame. I checked the manual and the only reference I see for using pan crop to zoom is if I am outputting that track to full frame. Is this possible?”
    If you change both the width and height the crop will zoom. I assume you disabled Local Aspect and Size About Center. Just re-enable them and grab a corner and move it inward and it will zoom.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Brad Leigh
    November 9, 2011 at 1:26 am
    John
    Again, my sincerest thanks!
    Brad
  • John Rofrano
    November 9, 2011 at 3:31 pm
    You’re welcome. I assume it worked. 😉
    ~jr
