Activity › Forums › Avid Media Composer › Zoom In On Video
Zoom In On Video
Posted by Arica West on April 20, 2010 at 11:33 pmHow do I zoom or push in on video using Avid Media Composer v 4.05? I tried Avid Pan and Scan but it only shows black.
Grinner Hester replied 16 years, 4 months ago 4 Members · 3 Replies -
John Pale
April 21, 2010 at 4:25 am3D Warp Effect or the old-school Resize effect.
Pan and Zoom is for still photos.
Hans Sieber
April 22, 2010 at 6:31 pmHi Arica,
you are working on a mac or pc? As John already mentioned the effect only works with stills. I got the same result using pan&zoom on a mac based avid. Next weeek I´m with this client to work out the problem. As far as the web told me there might be an issue with the pan&zoom plug in. It should have been fixed with the version 4.05. You could try to install the older pan&zoom effect plug-in of your 3.0 version. There is a problem with the newer (4.0…) versions.
Maybe this helps in your case.Hans
Grinner Hester
April 26, 2010 at 12:49 amya don’t. While resize will work, you really otta use AE so it doent tear the image quality up so much.
