Activity › Forums › DSLR Video › zoom h4n shoot wav or mp3
Posted by Ben Traylor on January 6, 2011 at 4:24 pminterviews will be shot on a 7D. what should i use on the zoom h4n, wav or mp3? for what’s it worth, i edit on final cut.
thanks,
benAnthony Bari jr. replied 15 years, 8 months ago 6 Members · 8 Replies -
Pete Burger
January 6, 2011 at 4:30 pmSince MP3 is a highly compressed format, and even in 320 kbps it’s kind of lossy, I think you’re on the save side to record in WAV.
48khz 24Bit should be enough for any kind of work in post. At least that’s what I was told by a sound technician – so this is how I work… -
Frank Giardina
January 6, 2011 at 5:34 pmThese Forums are GREAT… I had the same question. I use a Zoom as well for my 7D. What about sinking up the audio to the video without using additional software. I do it right in FCP by marking obvious peaks on the 7D & Zoom and then I match them up in the time-line. The thing I dislike most about this is it’s difficult to make fine adjustments.
Frank Giardina
17 Video Production -
Jason Jenkins
January 6, 2011 at 6:03 pm[Frank Giardina] “What about sinking up the audio to the video without using additional software”
You don’t want to ‘sink’ your audio unless you are working on submarine footage. In every other case, just sync it.
[Frank Giardina] “I match them up in the time-line. The thing I dislike most about this is it’s difficult to make fine adjustments.”
Select the audio and use Alt+arrow keys to nudge the clip one frame at a time.
Jason Jenkins
Flowmotion Media
Video production… with style! -
Frank Giardina
January 6, 2011 at 6:12 pmThanks Jason… yes, SYNC 🙂
Alt L-R Arrow… got it! Thanks again Jason!
Frank Giardina
Andrius Simutis
January 7, 2011 at 3:38 amFor synching audio without the fuss, try pluraleyes. It does it for you.
https://www.singularsoftware.com/pluraleyes.html -
Andrius Simutis
January 7, 2011 at 3:40 amWavs are essentially the same as .aif so that’s the way you want to go. Make sure you choose the 48khz setting so that your audio doesn’t drift when you try to line it up with your footage.
Anthony Bari jr.
January 8, 2011 at 12:49 amwav, less compressed, SD cards are cheap anyway. record with less compression. You cant work well with mp3’s in FCP.
*Production*Post-Production*
Apple Certified Instructor (Final Cut Pro 7)
“Semper Fi USMC”
